Infinity router multi templates and tape
Forum topic by JerryinCreek posted 11-27-2017 04:17 AM 627 views 0 times favorited 6 replies Add to Favorites Watch
View JerryinCreek's profile
JerryinCreek
215 posts in 2038 days
11-27-2017 04:17 AM
I purchased templates for the 4×7” butterfly and heart templates. I also purchased the clear double-sided tape they recommended. The templates are great! Very thick acrylic and accurate. IMHO the tape is horrible! I made a test cut with the butterfly template and the tape left horrible glue residue on the templates! It took forever to clean this——off using WD40 and then 409 to cut through the oil. What a mess! This adhesive roll was over $25! I then went back to my trusty standby Spectape, it was a no brainier!
The Spectape was:
-A little thicker, I could use a putty knife to lift the template (not a chisel)
-A great hold with no gooey residue
-Much lower price
Infinity template system:
Yes to the templates
Absolutely no to the tape!
-- Jerry, Johnson Creek, WI "If it was meant to be different it would be."
View pintodeluxe's profile
pintodeluxe
5797 posts in 3010 days
#1 posted 11-27-2017 04:24 AM
The carpet tape that Lowes sells is pretty good for templates.
View Gilley23's profile
Gilley23
489 posts in 579 days
#2 posted 11-27-2017 05:09 AM
Would it be easier to just clamp down the templates?
JerryinCreek
#3 posted 11-27-2017 01:10 PM
They would get in the way for your router.
View Lazyman's profile
Lazyman
2608 posts in 1584 days
#4 posted 11-27-2017 01:48 PM
For future reference, Goo Gone is excellent at removing tape residue.
JerryinCreek
#5 posted 11-28-2017 01:06 AM
Tnx! All I had was Goof Off which would have destroyed the acrylic.
Lazyman
#6 posted 11-28-2017 01:45 PM
- JerryinCreek
I don’t think I’ve ever tried it on acrylic so definitely check before you do.
