Chipped Blade Tooth
Forum topic by dpwalker posted 02-25-2011 10:12 PM 921 views 0 times favorited 6 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 3070 days
02-25-2011 10:12 PM
Hiya folks, Ihave a Freud combo blade that I’ve had less than a year & only used it lightly. I completed 4 small projects with it. I noticed a tooth with a chip on the tip that runs about 3/4 of the way across the top length ways. The shard was sticking up & I yanked it off. The question is: Is the blade safe to use as is or can I expext it to come apart?
-- You have not really lived until you do something for someone who can never repay you.
View pintodeluxe's profile
pintodeluxe
5817 posts in 3052 days
#1 posted 02-25-2011 10:20 PM
I would generally regard a blade with one chipped tooth as safe to use. It’s hard to say without seeing it. Carbide is hard, but brittle too. That’s the trade off I guess.
View DaddyZ's profile
DaddyZ
2475 posts in 3279 days
#2 posted 02-25-2011 10:36 PM
I Have a 7-1/4” Circular Saw Blade that I use to cut slats off Pallets, Missing 5 Teeth Many More Chipped!
View knotscott's profile
knotscott
8178 posts in 3614 days
#3 posted 02-25-2011 11:27 PM
It’s probably fine, but whatever chipped the one tooth may have also wounded others. You could always have it checked by a professional sharpener if you want to be certain. This is also a good excuse to get a new blade and use the old one as a backup.
View TheDane's profile (online now)
TheDane
5575 posts in 3901 days
#4 posted 02-25-2011 11:33 PM
dpwalker—I’m with knotscott … you have no way of knowing whether whatever chipped that tooth may have weakened the brazing on others. Those little pieces of carbide would do some serious damage if they came flying off the blade at 3600 rpm.
—Gerry
View Howie's profile
Howie
2656 posts in 3161 days
#5 posted 02-26-2011 12:31 AM
send it back to Freud and they will fix it.
-- Life is good.
View tenontim's profile
tenontim
2131 posts in 3983 days
#6 posted 02-26-2011 12:43 AM
If Freud won’t fix it, Forrest will.
