Moving a cabinet saw - questions!
Forum topic by builtinbkyn posted 11-25-2017 06:08 PM 770 views 0 times favorited 12 replies Add to Favorites Watch
View builtinbkyn's profile
builtinbkyn
2654 posts in 1146 days
11-25-2017 06:08 PM
OK I see the prudence in removing the table wings, but what should be done to ensure the motor and trunnion are secure/protected? Tilt to 45 and lower down on to some blocking? I don’t recall how it arrived.
-- Bill, Yo!......in Brooklyn & Steel City :)
12 replies so far
View EarlS's profile
EarlS
1958 posts in 2554 days
#1 posted 11-25-2017 06:14 PM
When we moved 5 years ago, the movers broke the start/stop switch. It cost ~$200 for a replacement since it was 240V. The wings, motor and such were just fine since they were so heavy. I also pulled the saw blade, out feed table, side table and fence guide off so they wouldn’t get damaged.
builtinbkyn
#2 posted 11-25-2017 06:18 PM
Hey Earl. Yeah I’m pulling the switch off for sure. I can see how that would easily get damaged. I also thought taking the wings off would be a good idea since the moving guys would be tempted to lift the saw by them and possibly crack the mounts.
I know there’s a position the trunnion/motor should be set to to minimize the possibility of it sustaining damage during transport.
View duckmilk's profile
duckmilk
3236 posts in 1530 days
#3 posted 11-25-2017 06:33 PM
I would contact the manufacturer—-or ask ToddJB who has moved and restored a bunch of old tools including cabinet saws.
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
builtinbkyn
#4 posted 11-25-2017 06:40 PM
Hey Duck. Was hoping Todd or MrUnix would drop by with advise :) Contacting Delta seems to be futile. I’m hoping for Internet support lol
View MrRon's profile
MrRon
5203 posts in 3449 days
#5 posted 11-25-2017 06:44 PM
Take out a term insurance policy on the saw; then stop worrying.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1052 posts in 1272 days
#6 posted 11-25-2017 07:04 PM
Bill, if you can take some scrap and make a pallet a little larger than the top minus wings before they come it would make the move smoother. The majority of the weight is at the top so pull the wings And blade off and crank the arbor to its highest point , lay the two wings on the pallet web down, take some cardboard and lay over them then turn the saw over and put it on top of the wings. Unfasten the control mount and store them in the cabinet. If the pallet has been cut large enough you can lock in the cabinet to the pallet with cleats or clamps.
-- "Tying shoelaces was way harder than learning to Whistle"
TheTurtleCarpenter
#7 posted 11-25-2017 07:08 PM
One additional thing Bill would be to pull off the hand wheels so they don’t get broke. Hope all goes well with the move ! Jeff
builtinbkyn
#8 posted 11-25-2017 07:22 PM
Hi Jeff. Thanks for that advise and the well wishes. I have the wings off, the switch off and the cranks off. What I now remember from when I received the saw- the arbor was tilted to 45 to get the mass to as close to the center as possible. So I did that and then put a piece of 4×6 bl;ocking underneath the motor padded with some closed cell foam I had. Then I lowered the trunnion so it bottomed out on the blocking. This should keep everything from moving. I have some 3/4” plywood I’m strapping the wings to so they don’t get dinged up. Other than that, the rest is up to the movers :)
TheTurtleCarpenter
#9 posted 11-25-2017 08:46 PM
Tell Willie, Ever tang gon be alright !
View AandCstyle's profile
AandCstyle
3179 posts in 2463 days
#10 posted 11-25-2017 09:58 PM
Bill, I made a shipping crate from ply and 2×4’s. Then I attached stop blocks wherever I thought there might be movement. HTH
-- Art
View TheFridge's profile
TheFridge
10767 posts in 1692 days
#11 posted 11-25-2017 10:23 PM
I set the motor in the bottom of the cabinet. Takes most of the stress off the trunnions.
