Flooring for tops
Forum topic by RussellAP posted 11-24-2017 03:26 PM 481 views 0 times favorited 6 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2196 days
11-24-2017 03:26 PM
Topic tags/keywords: table wood flooring
Has anyone tried using hardwood flooring for table tops? I had my bathroom remodeled and they used Acacia wood, it’s not perfectly flat, it bevels a bit at the joint. I wonder if properly sealed, if it might be a better alternative to expensive hardwoods.
So Advice, opinions?
View MrRon's profile
MrRon
4639 posts in 3153 days
#1 posted 11-24-2017 06:23 PM
Wood flooring is designed for floors, not table tops, but if you can find the hardwood used for bowling alley and gymnasium floors, that is flat enough for a table top. It should be readily available in maple; I don’t know what other woods would be available.
View HouseMover's profile
HouseMover
2 posts in 93 days
#2 posted 11-24-2017 10:05 PM
I bought some pre-finished hardwood acacia for that intention, but haven’t made the table yet. I am thinking of making my kids a tree house and will probably use it furniture in the little house. I have too many projects going on right now, maybe after I get a few house leveling jobs done next month I can breathe and show you a picture of my tree house. I would be interested to seeing your finished product if you make that happen,
Thanks in advance,
-- -Justin the HouseMover at http://www.lafoundationrepairs.com
View sawdustdad's profile
sawdustdad
354 posts in 794 days
#3 posted 11-25-2017 12:52 AM
Only problem I see with using flooring for a table top is crumbs, dirt, water, etc. getting in the joints. If you were to rip off the T&G edges and edge glue it, it should eliminate that issue and work fine.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View JCamp's profile
JCamp
522 posts in 460 days
#4 posted 11-25-2017 12:59 AM
My buddy did a bar top with it and it turned out good. I always thought the flooring would hold up well as long as it didn’t get to wet like around a sink.
-- Whatsoever thy hand findeth to do, do it with all thy might
View EyeUrnMayDen's profile
EyeUrnMayDen
5 posts in 247 days
#5 posted 11-27-2017 03:02 PM
I had a pretty beat up coffee table that was bound for the trash, decided to put some prefinished 3/8” oak flooring over the top, and it looks exactly like flooring on a table top. crumbs and spills DO get in the cracks. If you top coated i’m sure it would hold up much better.
