The carbide puzzle
« back to Woodturning forum
Forum topic by ginasdad posted 11-24-2017 03:03 PM 903 views 0 times favorited 16 replies Add to Favorites Watch
View ginasdad's profile
ginasdad
15 posts in 3355 days
11-24-2017 03:03 PM
Topic tags/keywords: carbide turning tools lathe
I started turning about 10 years ago and was puzzled that carbide was not used in turning tools. At the time I would touch up my steel turning tools every few minutes because I liked the feel of the sharp tool. I found some carbide cutting bits for metal lathes and shaped them to match my steel tools. I was very pleased to find I had a tool that would last for an entire bowl turning. When I would mentioned this to turners I ran into I got a dismissive response. ‘This was a scraper’ or ‘you can’t get as good an edge’. Neither matched my experience. I had to give up turning for 5 years and have just got back at it. Now carbide tools are readily available. I read everything I could on the carbide tools and came to the conclusion that the commercial carbide tools are very different from those I made. The commercial ones are flat discs or other shapes supported by a steel holder. These present a knife edge to the turning wood and generally allow for a scraping action. The ones I made are similar to a steel bowl gouge in the cutting edge shape. This facilitates the ability to get a cutting action from the tool. As for the sharpness of the tool, I’m sure the steel is sharper but not for long!. So perhaps the evaluation of carbide tools should include the shape of the cutter rather than just the material it is made of. This is only my experience but it explains to me the profound difference between my experience and what I was reading. Any thoughts?
-- so much wood, so little time
16 replies so far
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#1 posted 11-24-2017 03:13 PM
What did you use to grind the carbide? Any special tools jigs or set ups?
TIA
ginasdad
#2 posted 11-24-2017 03:34 PM
A bit slow, but I just used the cheap diamond hones that I had picked up at Princess Auto. By hand, by eye.
View Bill White's profile
Bill White
4929 posts in 3956 days
#3 posted 11-24-2017 03:37 PM
I have both, use both, like both.
I think it is the same mind set that existed when air tools for construction developed. “Ain’t usin’ them newfangled doodads. My hammer is fine.”
Bill
-- bill@magraphics.us
View Wildwood's profile
Wildwood
2305 posts in 2131 days
#4 posted 11-24-2017 04:21 PM
With no pictures didn’t happen.
Biggest draw back to carbide steel is cost and need to replace when can no longer sharpen. True most commercial carbide tools are scrapers but that’s okay for somethings turners turn they cannot be beat. Talking about dense antlers, exotic woods, bone or stone.
Yes carbide scrapers are okay for what they can do but don’t think will ever completely replace conventional turning tools. Not sure average turner has time or money to make their own cardbide gouges, but prehaps some company will start making them some day.
-- Bill
ginasdad
#5 posted 11-24-2017 05:04 PM
This is a very nice carbide router bit that worked right out of the box. 2 edges is a bonus. A little tricky to use so takes full attention. Very good on the inside of bowls that have a smaller opening on top.
View MrRon's profile
MrRon
4764 posts in 3239 days
#6 posted 11-24-2017 06:14 PM
Carbide used to turn wood will always act as a scraper. Carbide, being a very brittle material cannot hold a knife edge. When carbide is used in metal machining, it relies on high speeds to attain mirror finishes. Scraping and cutting is really the same thing. The difference being in the angle between the tool and the work. HSS tools can be sharpened to a very acute angle, but can’t work at the same speeds carbide can. Carbide is ground at a much less acute angle and so the edge holds up better without fracturing. There are also many different grades of carbide, but sharpness is a trade off for strength.
View Woodknack's profile
Woodknack
11611 posts in 2376 days
#7 posted 11-24-2017 07:27 PM
I’ve used carbides out of the box and they do not cut as cleanly as gouges but they do well enough that it’s just a little extra sanding. IMO, gouges cut cleaner and faster. The only real advantage of carbide is it stays sharp longer and has very shallow learning curve. I like carbide for roughing very hard woods, saves sharpening.
ginasdad
#8 posted 11-24-2017 08:11 PM
MrRon, this is where my inexperience comes in. I just assumed that since a continuous shaving comes from my cutting edge that it is cutting not scraping. But since I am using carbide I must be scraping.
Wildwood
#9 posted 11-25-2017 02:19 PM
Regardless of the steel used to make a tool you can get shavings when scraping. Reed Gray shows how his big ugly tool for example. More than anything depends upon your skill and wood you are turning more that tool steel.
https://www.youtube.com/watch?v=n4x8pZN6pNM
Can remember when carbide cutters being talked about on diferent forums by wood turners looking for the perfect tool. Yes in early days carbide router bits one type of cutter used by turners. Those discussions got technical but most turners had a wait & see attitude back then. Few guys were selling their carbide tools with various cutters via word of mouth.
Wasn’t until vendors got into selling them and mass marketing by Hunter & guy from Easy Wood that saw carbide tool selling briskly. By then also had and still have guys buying cutters and making their own tools.
Do carbide tools live up to all the hype? Answer is both yes and no. Yes the learning curve is not that difficult, and appeals to turners that don’t know or want to invest in sharpening systems. Down side is replacing cutters once dull. If buy in bulk prices of cutters not that bad, have to shop around.
https://azcarbide.com/
Are they faster than conventional turning tools? No not really! Like posted earlier they do excel at turning antler,
bone, exotic dense hardwoods, and stone.
While not perfect this testinG of various turning tool steels very interesting even though did not use carbide cutters in their test. You can read and decide for yourself. Biggest point should take away from the testing is found in two sentences.
“ All of the steels advertised as being more wear resistant than M2 are truly more resistant. However, the relative wear resistance less than claimed.”
http://www.nmwoodturners.org/files/ZerbySharpening/Tool%20Wear%20Testing%20by%20Jim%20Staley.pdf
No matter what steel is used to make your turning tool, need to sharpen when dull.
-- Bill
View msinc's profile
msinc
382 posts in 500 days
#10 posted 11-25-2017 03:04 PM
As a machinist by trade I have probably used more carbide than many people, but it was mostly on metal. I have used it quite a bit for wood. The two biggest things about carbide and wood are that it cost more and it stays sharp longer…that’s really about it. It will cut and it will scrape either way, wood being so much softer. From what I see in regards to using it for a wood lathe tool, it all comes out in the wash. You can spend the money and move on with the project or you can spend the extra money as time stopping to sharpen your lathe tool.
It’s really the special uses that make the difference. Turning very hard wood or materials or wood that has a lot of minerals and “sand” in it could make it necessary. Same with metal…it’s just harder so it is used to machine very hard metal. I can tell you that with metal it does not like an interrupted cut and will break easily. For cutting metal it does not like high speed either. Most things machined fast out of metal are done with CBN tooling and have been for some time now.
MrRon
#11 posted 11-25-2017 07:10 PM
I would use carbide for rough turning and HSS for finishing as HSS will yield a finer finish.
ginasdad
#12 posted 11-26-2017 03:46 PM
Wildwood, thanks for the reply. Very interesting about Reed Gray and the myrtle wood turners! I would try one of his ‘big uglies’ but the cost of the Tantung is a bit steep and hard to source. I have never had to pay much for my carbide bits. Not more than $10 and easy to buy.
Thanks to all the replies. You have helped round out my understanding of the facts and myths surrounding carbide, cutting and scraping!
MrRon
#13 posted 11-26-2017 06:41 PM
Here is a sample of the various shapes of carbide inserts that are available
https://www.mcmaster.com/#carbide-inserts/=1afcd1o
https://www.mcmaster.com/#carbide-inserts/=1afcdvg
View gwilki's profile
gwilki
200 posts in 1470 days
#14 posted 11-26-2017 06:50 PM
Ginasdad: Anyone who says that carbide on wood will always act as a scraper is mistaken. If you look at Mike Hunter’s carbide cutters, for example, they are not the flat piece of carbide used by companies like Easy Wood. Mike’s are a dished carbide cutter, with which you can ride the bevel and take cutting shavings, not scraping shavings. In fact, Mike’s tools do not make good scrapers at all.
There are other tools similar to Mike’s; they use dished cutters also. You can look on Youtube for videos of John Lucas demonstrating Hunter tools to see that carbides are for more than scraping.
It is not unreasonable, therefore, to believe that your tools may be capable of more than scraping. I would like to see a picture of the tools/cutters you made to see if that is the case.
-- Grant Wilkinson, Ottawa ON
Woodknack
#15 posted 11-26-2017 10:48 PM
- Wildwood
If you use a carbide scraper on a green wood you’ll get a nice ribbon coming off the tool. If you use it on kiln dried wood you’ll get a stream of chips off the tool. That’s my experience anyway.
