Cutting board woods?
Forum topic by sgtq posted 02-24-2011 07:25 PM 18403 views 0 times favorited 9 replies Add to Favorites Watch
View sgtq's profile
sgtq
370 posts in 2798 days
02-24-2011 07:25 PM
I am wanting to make a cutting board, I just recieved a bunch of 3/4 thick beautiful black walnut and I want to pair it with a lighter/white wood, this is my first cutting board so I know it needs to be non open hardwood, but the only other hardwoods i have access to right now is Whitewood, Poplar and Oak are any of these ok or do I need to look for some maple or other wood? Thanks for the Help in advance.
-- There is nothing wrong with America that cannot be cured by what is right with America. ~William J. Clinton
9 replies so far
View chrisstef's profile (online now)
chrisstef
17640 posts in 3128 days
#1 posted 02-24-2011 07:31 PM
im pretty sure that as long as its white oak you can use it .. red oak is porous.
View childress's profile
childress
841 posts in 3663 days
#2 posted 02-24-2011 07:51 PM
Whitewood isn’t a hardwood. It’s a generalized description of several different softwoods. I have had success joining softwood with walnut, but you need to make sure it doesn’t contain pitch/resin….
Poplar will work as will oak, but like chris said above, red oak has open pores while white oak has closed pores and is more suitable for cutting boards. Maple is obviously a great choice as it’s been used in butcher blocks for a long time.
-- Childress Woodworks
View sgtq's profile
sgtq
#3 posted 02-24-2011 09:17 PM
So I should be ok with poplar?
childress
#4 posted 02-24-2011 09:30 PM
yes… just note that it is softer than walnut so when you sand the board, it will take more of the poplar down than the walnut. You might get a slightly wavy surface after this, but it will still work fine as a cutting board.
View christopheralan's profile
christopheralan
1126 posts in 3842 days
#5 posted 02-25-2011 04:34 AM
I have used poplar for a few cheese boards I did a while back and they work great. You can get some really nice color combos if you pick through the stack.
-- christopheralan
View reberly's profile
reberly
191 posts in 2810 days
#6 posted 02-25-2011 04:47 AM
I prefer ginko. It is used heavily in Asia for cutting boards. It is supposed to release antibiotic agents when cut so it cleans the knife edge during use.
Rich
-- "Big Timber is our Legacy" , http://eberlywoods.com
View Cornductor's profile
Cornductor
208 posts in 2788 days
#7 posted 02-25-2011 04:51 AM
If your looking for a light colored wood use Maple. It’s a tight pored grained and it’s tough, the poplar is a softer wood and will mare easily with cutting. I use cherry and maple on all my cutting boards and then give them a proper seal.
-- An investment in knowledge pays the best interest. Benjamin Franklin
View CaptainSkully's profile
CaptainSkully
1601 posts in 3680 days
#8 posted 02-25-2011 05:36 PM
Don’t forget any “nut” woods (e.g. walnut) may set off people with nut allergies.
-- You can't control the wind, but you can trim your sails
View MashMaster's profile
MashMaster
134 posts in 2781 days
#9 posted 02-25-2011 10:49 PM
What about Alder, would that work? I recently came into possession of some 2” Alder and 2” Mahogany scraps that I thought might work for making a cool cutting board.
-- - Dave ; Austin, TX
