Does any one know of a good technique or link to a good technique for drawer designs with "stops" for a jewelry box? I have done a few jewelry boxes recently but am trying to figure out the best way to incorporate stops for sliding drawers. What is your favorite drawer system for a small box that incorporates a stop to keep the drawers from falling out if pulled too far?
You know, the key to a really good drawer is making it glide smoothly over 3/4 of its length and then slowly tighten in its opening so that at full extension it self clamps side-to-side and takes some effort to remove it completely. It means at the back the drawer is fractionally larger then at the front, not requiring stops of any sort.
The drawers I'm talking about and what I picture as drawers in a jewelry box are simple box-in-box or pocket drawers, in other words no mechanisms or runners or anything. I'm fitting individual drawer parts prior to assembly to the opening making sure the front just fits in place and the back of the drawer might hang in the opening but won't pass through, nothing new here perhaps. Taking the step early on of, one way or the other, ensuring more space at the back of the pocket simplifies fitting. Once the drawer sides and front are all dovetailed and before the bottom is slid into its groove I plane it with the sharpest plane to the fit I am aiming at. The pre-fitting before assembly gets you well on your way and just normal cleaning up of the joinery should get you close. It really is a nice feeling to get the action on such a drawer, considering the hygroscopic nature of wood at all times, just right. Very easy to pass the sweet spot in a hurry so caution is called for.
I know nothing of this Charlesworth figure but in all fairness and for the record it is Krenov who popularized this method in The Fine Art of Cabinetmaking where he credits it as a criteria for judging the "master piece" of students who complete their formal cabinetmaking training in Sweden. So it isn't something that can be attributed to an individual but is more an arbitrary standard established by tradition.
A technique I have used is to cut the drawer sides about 1/4" lower then the face. The back piece is left full height.
Small blocks of wood (3/16" high) are attached to the top of the opening at the sides and act as stops as the drawer is pulled forward (they contact the drawers back panel.
To completely remove the drawer, the drawer is tipped up and out.
Splinter's would also work as a piece hanging down along the back far enough that it catches on the face as you pull it out. You'd have to leave enough room to angle it.
I did something similar for a dresser I built the wife years ago but the block is up front and hangs down from the top. It worked for what I did but I probably won't do it that way again
Cowboys suggestion is the traditional fix and simplest, if your jewelry box uses a face frame.
I often use a commercial metal tab on the rear of the drawer that flips out of the way for removal when there is a face frame present.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
