16" Buss Machine Works Jointer Restoration and Upgrade
Forum topic by AZWoody posted 11-22-2017 01:42 AM 604 views 0 times favorited 13 replies Add to Favorites Watch
View AZWoody's profile
AZWoody
1330 posts in 1217 days
11-22-2017 01:42 AM
Well, I finally got it finished. I had posted a while back when 2 jointers arrived to my shop. One was a 16” and the other a 20”
It took a while to get the free time to get it all done but I finally got it all broken down, repainted and upgraded the cutterhead to a custom spiral head from Hermance Machine Company in Pennsylvania.
I’ll do this in 2 posts. This first post will have the original photos of the machine.
It is from Buss Machine Works. I am still researching model numbers, etc but this is pretty close to 100 years old, if not more.
Here is the before photos…
13 replies so far
View Holbs's profile
Holbs
1863 posts in 2022 days
#1 posted 11-22-2017 01:58 AM
looks like a big model of the USS Enterprise, minus the tower :)
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
AZWoody
#2 posted 11-22-2017 02:14 AM
Holbs
#3 posted 11-22-2017 02:17 AM
and I thought my restorations were impressive
AZWoody
#4 posted 11-22-2017 02:20 AM
- Holbs
They really are. I’ve seen your work. I am able to cheat though. I have employees, plus front loaders, pressure washer and a sand blaster, haha.
View Aj2's profile
Aj2
1381 posts in 1791 days
#5 posted 11-22-2017 02:23 AM
That’s awesome I’ve never used a hermance head did they say what the max depth cut is? Looks like a very big gap in between the infeed and the head. Maybe the table is slide back?
I like the blade guard much more than a pork chop.
-- Aj
AZWoody
#6 posted 11-22-2017 02:27 AM
That s awesome I ve never used a hermance head did they say what the max depth cut is? Looks like a very big gap in between the infeed and the head. Maybe the table is slide back?
- Aj2
I have the table back to show the cutterhead better. It closes in pretty close. I believe equal to what the outfeed is set at. I have not asked what the max depth is as I rarely take much on a jointer but there are very large channels in front of each row of cutters that could handle quite a lot of chips.
One thing that was an added bonus was they sent a torque wrench along with the corresponding torx socket needed to install each of cutter.
AZWoody
#7 posted 11-22-2017 02:57 AM
- Aj2
Also, on the blade guard, I really, really like this one. As the board is fed through, it floats up and over the top so it never moves out of position. It just rises and does not get in the way.
For edge jointing, then it can be pulled out a bit to the side to give way for the board to ride along the fence.
The 20” has a porkchop guard and I have no idea how to manage a slab that wide and use the guard. It seems a bit dangerous to try to work around it as it is all the way in the open position. I feel I would be leaning over and really reaching off balance to try to put the pressure on the outfeed side.
Here’s 2 more pics of the guard in different positions. The first is it raised up, as if a board is going underneath. The other is from the back side where you can see it swung out for edge jointing.
View PPK's profile
PPK
1000 posts in 802 days
#8 posted 11-22-2017 02:38 PM
Awesome!!!
-- Pete
View HokieKen's profile
HokieKen
4949 posts in 1132 days
#9 posted 11-22-2017 08:28 PM
That’s awesome Charles!
-- Kenny, SW VA, Go Hokies!!!
View chrisstef's profile
chrisstef
17376 posts in 2999 days
#10 posted 11-22-2017 08:34 PM
My gawd …. drool …..
View Ripper70's profile
Ripper70
990 posts in 902 days
#11 posted 11-22-2017 08:44 PM
Wow! You turned that machine from an anchor for an aircraft carrier into a magnificent wood cutting, sawdust making cast iron beast! Nice job!
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View BurlyBob's profile
BurlyBob
5487 posts in 2259 days
#12 posted 11-22-2017 09:44 PM
That is absolutely amazing!
View Marlow's profile
Marlow
172 posts in 2664 days
#13 posted 11-22-2017 09:50 PM
Wow! Nice! I mean, keeping old American iron going: Really nice.
