Vinyl replacement windows.
« back to Coffee Lounge forum
Forum topic by mike02130 posted 11-20-2017 07:37 PM 448 views 0 times favorited 5 replies Add to Favorites Watch
View mike02130's profile
mike02130
167 posts in 787 days
11-20-2017 07:37 PM
Hello,
Quick question. I had some vinyl windows installed in my house. I’m having issue with the installation. The windows replaced bad windows which replaced the original double sash windows with weights.
The height of the rough opening is 3/4” taller than the window, thus leaving a 3/4” gap at the head. They tried to remedy this gap by sandwiching two pieces of vinyl L material together. Like a z channel placed vertically. However, because the Gap is so wide, there is a gap of light and air coming in.
I’m in the process of talking with the installer. I would like to be armed with information when I speak to him. Ok
So, with no further ado, the quick question is, how much less should the window measure in height than the measurement of the rough opening?
Thank you.
-- Google first, search forums second, ask questions later.
5 replies so far
View Gilley23's profile
Gilley23
489 posts in 496 days
#1 posted 11-20-2017 07:53 PM
It would help if you posted pictures of the inside and outside of the house. What kind of siding do you have?
View corelz125's profile
corelz125
501 posts in 1090 days
#2 posted 11-21-2017 02:19 AM
3/4” is a bit of a stretch but there should be a sort of vinyl channel cap. Between that cap and the window they should have put some type of insulation either the pink stuff or spray stop gap. Is there a window stop on the top? Also are they going to cap them on the outside with aluminum?
mike02130
#3 posted 11-21-2017 02:24 AM
Thanks guys. It’s been fixed. Window guy messed up on ordering. Too short. Installer tried pulling a fast one and tried to cover his bosses ass. They’ll get fixed. Thanks again.
View Dark_Lightning's profile
Dark_Lightning
3215 posts in 3223 days
#4 posted 11-21-2017 04:33 AM
Good to see. Air gaps are completely unacceptable in a window installation.
-- Random Orbital Nailer
View JenniferMichaels's profile
JenniferMichaels
6 posts in 302 days
#5 posted 11-23-2017 04:50 AM
Good to know that your problem is resolved. Most of the times the window designs are good and the problem is with the installation of the window. Some of these details have to be seen while installing like, air gaps and proper insulation.
