Who recognizes this jointer?
Forum topic by Schummie posted 818 days ago 887 views 0 times favorited 13 replies Add to Favorites Watch
View Schummie's profile
Schummie
168 posts in 1934 days
818 days ago
Topic tags/keywords: question jointer
Dear friends,
I have a little question, who recognizes this jointer?
I believe it is an American model, when I look at the attachment point of the safety cutter guard.
The jointer is standing in a old barn in the Netherlands.
I hope someone can help me.
Thanks Henrie.
-- Greetings from the Netherlands.
13 replies so far
View Raymond's profile
Raymond
665 posts in 1896 days
#1 posted 818 days ago
Hi no idea on the manufacture. But if you don’t want it and are willing to send it to Wisconsin. I’ll take it.
-- Ray
12053 posts in 1510 days
#2 posted 818 days ago
looks like an old rockwell – delta
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110528183904&hlp=false&rvr_id=212868805688&crlp=1_263602
good luck
they are good
and still have parts
View dbhost's profile
dbhost
4748 posts in 1401 days
#3 posted 818 days ago
It’s hard to tell with any certainty because of the extent of the missing parts, but it appears to be an old Rockwell / Delta. Take a look at the OWWM website (Old WoodWorking Machines) and you might just be able to identify that thing…
View BTKS's profile
BTKS
1919 posts in 1633 days
#4 posted 818 days ago
patron and dbhost have pointed you in the right direction. I too would guess as a rockwell / delta. Age, ???
There may be an out of the way data plate somewhere. I would check the inside of the stand or the underside of the tables and base.
Good luck, looks like a keeper.
Took another look. Appears to be rewired, probably due to voltage and hertz differences. If the motor has info on it I wouldn’t use it for anything related to the jointer. I would pull the belt shield and see if there is a data plate behind it. Hope this helps.
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View Lee Barker's profile
Lee Barker
1887 posts in 1019 days
#5 posted 818 days ago
If it were an (original) Rockwell/Delta, the paint would be battleship gray. If the color I’m seeing on my computer is accurate—looks a little like a green—I would suspect it is a Taiwan copy.
Early RDs were on an open stand with heavy angle iron legs which flared to rounded feet. This is a thin sheet metal base, which still looks factory, but does not look RD to me.
I had two similar Rockwell Deltas and they had chrome handwheels with all rounded surfaces, nothing like the handwheels on this fella.
I’m thinking Taiwan, maybe Sunhill. Open to other opinions and observations, to be sure.
Kindly,
4883 posts in 1817 days
#6 posted 818 days ago
I agree with Lee.
That’s the same pattern as some of the pacific rim copies from the
1970s and 80s. Some of them are 7” jointers, which is pretty much
a giveaway. While I cannot say no American tool maker never made
a 7” jointer, I don’t recall ever seeing one mentioned.
Jointers are simple machines. If the tables and fence are straight and
the bearings are tight, that jointer should work just fine for you, brand
name or not.
View superstretch's profile
superstretch
1457 posts in 862 days
#7 posted 818 days ago
Looks a little bit like the old Jet jointer my dad just picked up, 70s or 80s maybe JJ6
-- Dan, Rochester, NY
View Rick L's profile
Rick L
513 posts in 1930 days
#8 posted 818 days ago
Asian clone without a doubt.
-- Few folks really know how to maximize the potential of their tools!
Schummie
#9 posted 817 days ago
Dear friends,
thank you very much for your help.
Finally I had found a nice and affordable jointer for me, it is not easy over here to find a good and affordable jointer..
When I look in the US, for example on Ebay, than you see a lot off nice machines.
I thought this is an old machine, but I was happy and I want to try to make him like he was, but now I don’t know
or it’s worth the effort.
I have also heard from the seller, that maybe the bearing is ware out, he gives a rattling sound.
What is wisdom?
Thanks again,
Henrie.
#10 posted 817 days ago
bearings can be replaced
if everything else is good
then you have a good jointer
Schummie
#11 posted 816 days ago
The seller sold him behind my back.
Henrie.
View MashMaster's profile
MashMaster
87 posts in 829 days
#12 posted 815 days ago
sorry, I hate it when that happens.
-- - Dave ; Austin, TX
View therookie's profile
therookie
891 posts in 996 days
#13 posted 815 days ago
I concurr that the planer is probably an old rockwell delta.
-- http://aewoodworks.webs.com
