sanding /prepping figured woods
Forum topic by tcarswell posted 11-20-2017 03:08 AM 896 views 0 times favorited 16 replies Add to Favorites Watch
View tcarswell's profile
tcarswell
80 posts in 1413 days
11-20-2017 03:08 AM
I’ve been doing a lot of smaller projects boxes /cabinet on stands etc. I work most of the time with domestic highly figured woods birdseye maple cirly maple /cherry /walnut. I have studied alot on finishing and trace coating etc. But I don’t hear a lot about the prep work . I tend to sand everything to 400 as I’ve noticed visible scratch patterns on wood sanded to 220 in the past (maybe I’m picky or overly cautious ) well I’ve seen lots of info about sanding figured woods to lower grit like 150 to 180. Is it beneficial to do that ? For that matter I can noticeably see the scratches at 150 grit I can’t imagine finishing at that point. Am I being overly picky or is something wrong with my sanding regimen ? I spend plenty of time going through the grits and I don’t skip any grits.
Thanks for any and all help folks
-- Nothing worth doing is easy ! (or simple) It's time to move past cultural Marxism. 120 million bodies is more than enough to learn that lesson .
16 replies so far
View sras's profile
sras
4866 posts in 3243 days
#1 posted 11-20-2017 03:29 AM
I do the same as you. Others may have better info but for me, I like how the wood looks and feels with the higher grits.
View Lazyman's profile
Lazyman
2383 posts in 1501 days
#2 posted 11-20-2017 03:52 AM
I haven’t done much with figured wood myself but I’ve read the same as you that sanding to the finer grits doesn’t help and might actual hurt the final finish. They said that instead of going to finer grits to us a well sharpened cabinet scraper for the finest finish on figured wood. I’ve seen this myself on a walnut piece I did a few years ago. It wasn’t figured but the finish left by the scraper was amazing.
View pottz's profile (online now)
pottz
2946 posts in 1098 days
#3 posted 11-20-2017 04:13 AM
well I think sanding to 150 or 180 is not enough to achieve a good finish,my rule of thumb is at least 220 grit.do what you think is right!
View JenniferMichaels's profile
JenniferMichaels
6 posts in 302 days
#4 posted 11-20-2017 05:22 AM
I have not actually worked on this, but i think Tcarswell, the method you are using is good one and it will work.
View tomsteve's profile
tomsteve
807 posts in 1333 days
#5 posted 11-20-2017 01:26 PM
the best way to find out is do some samples.
View OnhillWW's profile
OnhillWW
131 posts in 1346 days
#6 posted 11-20-2017 01:34 PM
I go to 400 or more with these types of woods. Doing so also helps to get the finish o be absorbed more evenly as with end grain. Other considerations:
Not all papers are created equal. Use quality paper – e.g. Klingspor, Festool, Mirka etc. They sort the abrasives to be very uniform and this will give a very even finish, also the granules stay attached to the paper rather than rolling around on your work.
Use a quality ROS sander, one with small orbits, quality tools will spell out the orbit in their spec sheet.
Always use good dust extraction from the beginning, i.e. 100 grit on down. Once material has been cut get it out of the way especially with harder woods but true for all. Even with good extraction when using grits in excess of 300 I clean the pad often with a rubber pad cleaner.
And technique plays a role as well. How hard to press, how to move the sander around the piece etc. Generally I focus on trying to get the pad to sit evenly on the work and applying little more weight than the sander itself. Keep it in motion never sitting still. Others may disagree but I start and stop the sander off the work surface, i.e. start it, move onto surface and sand, remove from surface and then turn the sander off.
-- Cheap is expensive! - my Dad
View OSU55's profile
OSU55
1826 posts in 2103 days
#7 posted 11-20-2017 01:40 PM
Dont think you are doing anything wrong. The final grit to prep with depends on the wood, the grain, and the finish schedule. Sandind with the grain on straight grain wood 180-220 is fine, but figured wood will show scratches. Pigmented stain will show any little flaw, dye wont. A film finish will fill in small scratches that wont show. As others said, test samples are the way to find out. Dedicate some shop time, lay out out a test plan, and try different things.
View bondogaposis's profile (online now)
bondogaposis
4925 posts in 2465 days
#8 posted 11-20-2017 02:31 PM
A lot depends on the wood. For instance open grain woods like oak, I sand to 180 grit and that is it. For finer grained woods like maple I go to 220 grit, but that is for ordinary grained wood. Also how you sand makes a difference. I always use a ROS that is hooked up to a shop vac. I believe that pulling the dust off as you go really helps with a better finish. Finally I will hand sand a few strokes with the final grit just to remove any swirl marks. If you see scratch marks then I wouldn’t hesitate to go finer. Have you ever noticed how wood turners will typically sand to 600 grit or finer? That is because they sand at right angles to the grain, and you have to go that fine in order for the scratches to disappear. With highly figured woods grain direction is all over the place making it nearly impossible to sand with the grain, so I think that sanding with finer grit is called for. Especially since smaller projects like boxes invite more scrutiny.
-- Bondo Gaposis
View Aj2's profile
Aj2
1643 posts in 1912 days
#9 posted 11-20-2017 03:04 PM
I don’t sand at all it’s been years since I bought sand paper. I will use a card scraper if I cannot handplane
-- Aj
tcarswell
#10 posted 11-21-2017 03:06 AM
Thanks for all your input. I use a mirka deros 5 mm orbit and a festool 2mm orbit and hand sanding at 400 to wrap up. I really could be way better with my planed and my scrapers. I have plenty of expensive ones I really should get to be better with. I watch doucette and wolfe videos and they don’t seem to ever use sandpaper and work almost exclusively with top top grade figured wood.
OSU55
#11 posted 11-21-2017 12:40 PM
I didnt mention planing or scraping since you were talking sanding, but if you have the tools that is the way to go. I plane or scrape everything I can. Dont use card scrapers much – rough on the hands. Cabinet scrapers (#80) or scaper planes are excellent tools. I do a light hand sanding with 320 to find any tool marks.
View rwe2156's profile
rwe2156
3066 posts in 1595 days
#12 posted 11-21-2017 03:16 PM
I’ve heard fine grits can interfere with oil penetration. Finer grits best done after staining, oiling, etc, right?
OSU55
#13 posted 11-22-2017 01:22 PM
I ve heard fine grits can interfere with oil penetration. Finer grits best done after staining, oiling, etc, right?
- rwe2156
Ive sanded up to 800 on the lathe and never found it to be a problem.
Lazyman
#14 posted 11-22-2017 01:49 PM
I have read that finishing with a scraper can create such a smooth surface that it can actually repeal stains and oil. In fact, I think that they said that because sandpaper was once pretty expensive it was mostly used to scuff the surface after scraping to help it accept an oil finish.
View bbrown's profile
bbrown
234 posts in 3666 days
#15 posted 11-22-2017 02:28 PM
I use a lot of figured wood: maple, cherry, walnut.
I sand surfaces to 150 and endgrain to 220.
The whole point of using figured wood is to maximize the figure and get it to really show, or pop with the finish.
For me, this is best achieved by avoiding anything finer than 220 grit.
-- Bill Micah 6:8
