I moved from FL to NC 2 years ago. Furniture went by commercial mover. Rented a storage shed and moved the tools in my truck and stored ‘til the house was ready. If moving a tool box, buy or find some cheap foam to cram in on top of the tools in the drawers so they cannot fall out even if the box is upside dowm. Movers will turn any item any orientation to get it in the truck. Make sure the box is LOCKED. Disassemble any heavy items to where there is not a lot of stress on anything critical (i.e. remove the cast iron wings from the table saw, motor if applicable, take the head off the drill press column, etc. Don’t sell any tools you like to use. They don’t make ‘em like they used to (that applies to anything 5+ yrs old!!) If you cuss it when you use it, sell it or give it away. Its not worth the cost to move it.
That said, PODS was not an option for me. If I could have packed them myself and locked the container, I would have considered it. IL to ID is a long drive. If you pack a container yourself, cram everything as tight as possible, do not stint on padding, and pack everything like it will be dropped from a 5 foot height. You never know when that truck driver will have to make a sudden “detour” across the interstate median to avoid a head-on collision. Things will vibrate against each other (the semi-trailers don’t have shocks), so use blankets to provide rub protection.
Don’t envy you the move, but can understand wanting out of IL. I was born and raised there, left to go into the military 41 years ago, and only went back to visit family while they were alive.
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
