Rockler Taper/Straight Line Jig
Forum topic by king_nickizzle posted 11-18-2017 08:05 PM 912 views 0 times favorited 6 replies Add to Favorites Watch
View king_nickizzle's profile
king_nickizzle
25 posts in 992 days
11-18-2017 08:05 PM
Topic tags/keywords: jig rockler tapering grizzly
I bought this recently, and the instructions say to put the jig in the miter slot on the table saw, and trim off the excess section of the jig to establish a zero clearance zone. However, my Grizzly Table Saw’s miter slots are fairly close to the blade when using this jig. Following Rockler’s instructions, I’m going to cut into the pre-made grooves. In images/videos I’ve seen, people haven’t had to cut this far into the jig to establish zero clearance. Do any of you have this jig? And if so, have you had this issue? I feel like the worst case scenario would be that I wouldn’t be able to put the knobs all the way to one side, but maybe there are more cons to cutting into the groove. Any advice? Thanks!
View Ripper70's profile
Ripper70
1085 posts in 990 days
#1 posted 11-18-2017 11:03 PM
Can you move the miter bar to the left enough so that it better accommodates your saw?
I thought that the fence was used to set the distance of the jig from the saw blade and not a miter bar.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View HunterDS's profile
HunterDS
47 posts in 581 days
#2 posted 11-19-2017 12:24 AM
I have the same issue. Either to far into the slots or when I reverse it its to far from the blade. My thinking is new holes might need to be made.
-- Hunter, Houston TX
king_nickizzle
#3 posted 11-19-2017 12:32 AM
Ripper70 unfortunately the miter bar isn’t adjustable (well, not that I couldn’t drill holes) with how Rockler set it up. Alternatively I can simply remove the miter bar and rely on my fence. Just seemed annoying that it wasn’t a universal set up.
Yea that’s what I was thinking HunterDS, just wanted to avoid that if I could.
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1656 days
#4 posted 11-19-2017 01:43 AM
Have photos of the miter bar set up top and bottom?
king_nickizzle
#5 posted 11-21-2017 01:56 AM
Got it figured out! There is an extra set of holes for the miter bar so you can unscrew the current lockup and shift it about an inch and a half over. I originally assumed the screw holes were for something else so didn’t think to move the biter bar, but turns out they are just extra for different saws.
View Lazyman's profile
Lazyman
2270 posts in 1468 days
#6 posted 11-21-2017 04:09 AM
It looks like the other miter slot is a little further away so perhaps the other option would have been to use it to the left of the blade?
