oil finshes
Forum topic by rdray posted 818 days ago 414 views 0 times favorited 1 reply Add to Favorites Watch
View rdray's profile
rdray
15 posts in 1236 days
818 days ago
Topic tags/keywords: finishing
I have built several boxes and jewelry boxes lately, some out of clear cedar trees I have cut down. I put a coat of linseed oil on the boxes which brought out and darkened the grain which I wanted. my question is, would tung oil or danish oil do the same thing? I think they would both be easier to work with. I put a couple of coats of polyurethane on after the oil has dried. any suggestions. thanks.
-- rdray
1 reply so far
View FaTToaD's profile
FaTToaD
236 posts in 1308 days
#1 posted 817 days ago
I built lots of boxes using redwood and I mainly use BLO for my finish. I use to use danish oil, but I keep forgetting to buy more. Both will darken the wood, as will tung oil from what I’ve seen. I have not used tung oil yet, but plan on getting some soon. Sometimes I feel like the boiled linseed oil darkens the readwood more, but I like the look of danish oil on oak better.
I agree the danish oil seems to cure faster and is a bit easier to work with, I don’t think you can go wrong with any of those options. I use to put wipe-on poly over the oil, but lately I’ve been using shellac. I find it easier to apply and you can get several coats on in a day. I just use the dewaxed shellac you can get from HD or Lowes.
Take a look at some of the boxes in my projects section, most are BLO and shellac. Hope this helps.
-- David
