hello, started installing cabinets as a business 3-4 years ago, installing with 3 of my brothers. We have a suppliers that build the cabinets and gets the contract for us and sub contracts the installing to us. We have been looking into starting to build the cabinets and are looking for tips on equipment and how to get jobs and where to bid. I live in Canada I the greater toronto area. Any help is useful, please help out and thank you.
A lot depends on the work you want to do.
There may be room in your market for another
shop that builds face frame cabinets. If you
want to build frameless cabinets however,
prepare to invest in some exotic equipment.
Woodweb.com has a lot of archived discussion
threads on various aspects of the cabinet
business. Try Googling terms like
"cabinet design software woodweb" or
"starting a cabinet business woodweb"
thanks for the tips and help, I'm trying to start building in my garage as i have not started renting out a shop yet. I'm looking into getting into commercial first as it's the simples to make cabinets for aka like box cabinets, what are some good table saws that aren't too big nd bulking that I can get to start off with?
Start looking for an edgebander, frameless cabinets need a lot of edge banding done to them.
I have an SCMI Basic 2 (3 phase) that has worked well for me for over 15 years.
You can get by with smaller hot air banders if you need to.
Look into the Schmitt32 line boring system. It's
inexpensive to get started with it and it does
things shelf pin jigs can't.
If you won't be buying a sliding table saw, take
a look at the EZsmart track saw system and
Festool. Frameless is mostly about panel processing
except for wood doors and drawer faces, which
you can outsource. Getting cuts straight enough
for edgebanding can be a real challenge on
a regular table saw without a sliding table. Track
saws, while they have their issues, at least cut
pretty darn straight.
Edgebanding capacity will be a limitation on the
jobs you can do. 3mm pvc banding is difficult to
manage if you don't have an expensive machine,
but it's the best banding for commercial work.
Edgebanders are complex machines. New ones are
pricey and buying a used one is a bigger risk than
many other types of used machines.
In my experience, it's hard to compete with the box cabinet makers (there are a lot of them). They quite simply can do it faster and cheaper. However, there usually seems to be demand for custom cabinet makers. You know, the guys that'll build a 14-3/8" wide cabinet that's 23-1/4" tall to fit in somebody's space, and that matches an existing style. You get the point. Custom. Otherwise, I'd think that you've got a good deal just installing box cabinets sourced from the "big boys."
So, if you choose to do a shop setup, it really doesn't take that much. I'm only giving advice on face-frame cabinets; I don't have much experience with Euro.
-Good 52" tablesaw
-Drum sander up to 24" capacity
-Panel saw is nice, but not necessary
-Couple/few routers, and a good router table for making the doors
-Few random orbital sanders and a belt sander
-An edge sander really makes life easier
-Dust collection
-Drill press is nice, but not completely necessary. Boring hinge holes and shelf pin holes is easier/faster with one.
-A planer. 12" lunch box planer works fine for the start. Otherwise a 15" one with helical cutter head.
-A way to spray finishes, as well as a 60-gal. air compressor.
-Obviously some drills, a couple trim nailers/staplers
Did I miss anything big?
I won't get into what brands/types of tools, it all comes down to what suits you best, and it goes JUST like the Chevy/Ford/Dodge/Toyota debate. You get the point.
I have all the stuff listed above, save the panel saw, and to be honest, I've been acquiring tools for many years, but have kept track of values. I'd say to get all that stuff started purchased, you're looking at a good $20K if starting from scratch. In USD anyway.
I haven't built kitchen cabinets or bath vanities in a very long time. If a job came my way today, I would buy the white boxes from IKEA and just make custom doors, drawer fronts, and benchtops. Not only are the boxes cut and edged, the good hardware is most likely better priced than I can buy it. These are modular boxes and you might need to make a few custom ones to suit the room, even then buy extra boxes to cut down.
You can outsource your cutting to size until you can afford a descent table saw.
You can outsource your shelf drilling machine until you can afford a descent line boring machine.
You can outsource your doors and drawers,
You can outsource your finishing until you can afford a spray rig.
You might as well just order pre fab cabinets until you can afford everything you are going to need,
beyond your current set up.
I've sent an email re: Jim Posts books. In today's market it's going to be difficult to do what you are thinking about. That's why you should explore these texts albeit a bit dated.
The folks who appear to be successful as one man type shops usually make very specialized art type cabinets to high end markets. To me that means seeking out architects and builders that cater to specialized clientele.
Huff's writings are indeed helpful especially as a guide to starting out. wish I'd have read that information before venturing out as your doing.
This may be unpopular, but--I think if I were going to start a cabinet business today, I'd look to outsource as much production as possible. It just makes better business sense to source doors, drawers, knock down casework, etc. from shops that have invested huge piles of money to specialize in those things. The real value add is right where you are already experienced- installation and customer service. You just need to add the sales side (and that can be outsourced too).
It may be fun and interesting to make boxes, but if you set that aside and evaluate it from a business viewpoint I think you will find that you can outsource your components cheaper than you can make them yourself and not have to staff up to run a shop, worry about keeping people busy, deal with all the environmental issues associated with finishing, etc.
In today's market, a business model based on outsourcing as much as possible just makes good business sense.
Seeking out architects is the best way initially. You will be competing with the CNC boys as well. Carving particularly large scale projects is usually what they want. If you can add this to your offerings then you can make a pot of money on just one project if it is commercial.
when I do casebuilt work or frameless as others call it. I use furniture grade plywood. I have dadoed in shelf clip frames or just dadoedin shelves no hole drilled. Hinges are a pain but homemade jigs make them manageable.
Ok I'm rambling so I'll shut up.
I agree the information is dated Tom but will still do the job for small-scale shop. Most small-scale shops can't compete unless you specialty work like you said but that usually takes years to establish.
Great ideas here, but I have to suggest that you go back to a1Jim's and my posts #2 and 3. Jim Tolpin writes in great detail about how he streamlined his processes to be able to provide a truly custom product from a one-man shop.
I think you have to be able to stand out from the crowd. Otherwise, stick with what you're doing if it works.
I am in agreement with you. Even pulled out my professional Cabinetmaker book from the shelf. It's relevant. And it is hard to compete with the quality of colors and finishes even from the box store? It does take talent tostand out as well as drive to compete. and nothing will beat perseverance.I get construction magazines and industry books from time to time, and that is where the money is.
If there is a niche then drilon4 needs to find it.
I will not stop doing installs completely , I want to be the guy that makes the cabinets and also installs them. lots of general contracts always tell me to build my own cabinets I will profit. I don't want to rent a shop or big equipment right away till I get some jobs to build. meaning that I'm trying to do small jobs where I can build the cabinets in my garage. thanks for all the tips.
I suppose a lot depends on what your business goals actually are.
A two-man shop in a small space with basic tools can produce very nice custom kitchens and make a decent living. Relatively low overhead, relatively inexpensive equipment expenses and only two wages to be paid from the proceeds.
Design, sales and installation of outsourced cabinetry can be scaled up quite large and quite quickly if you have the clients. A close friend was doing $25M in gross sales per year this way, not too long ago. (He started from his 2 bedroom apartment.)
What I consider a mid-sized shop, $1M to $5M gross sales per year, is a tough model to make money in and it takes a lot of fiscal discipline and focus to not lose your shirt. Expensive equipment, expensive real estate and expensive labor can get the best of you if you aren't paying proper attention, or, if your market shifts and you don't shift with it.
I wouldn't go into something like this without a clear definition of what your success looks like and a step by step plan of how you are going to get there. The ABC's of building cabinetry is almost secondary to this business objective.
Yes the ABC's are indeed almost secondary. They will be secondary when you get large and buisy. Cash flow management will be the common thread throughout your business life.
I think you will enjoy using your creativity in designing your works.
well basically, what my plan is. start up with doing someone work for my garage and than moving onto my kitchen. I have everything but I'm still looking for a good sized table saw that is great for cutting sheets that will be bought from a supplier that are 8ft by 8ft. than I plan on getting word out that I'm building cabinets maybe for friends that are g.c. than hopefully getting into small commercial jobs. it will be me and 3 others brothers doing this so, we will still keep the install going until we get too busy to go out nd install our selves so money is always coming in.
You can get a 9 or 10 ft. sliding table saw with an
outrigger. Those big panels will be awkward and
the saw will take up a lot of space but it will handle
the work.
Altendorf, SCMI and many other makes are available.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
