Your thoughts on finishing ornaments?
Forum topic by becikeja posted 11-16-2017 12:23 PM 475 views 0 times favorited 6 replies Add to Favorites Watch
View becikeja's profile
becikeja
919 posts in 2930 days
11-16-2017 12:23 PM
I need to turn and finish 30 Christmas ornaments over the weekend. These will be simple balls with an epoxy insert. I do very little turning, so this will be an adventure. Did a test run this past weekend and the design came out pretty good. Mahogany (because I have a piece 12/4 on hand) sanded to 400 grit.
Looking for a fast finish that will give a shine with one coat.
I am considering Mylands High Friction Polish, and Shellawax, but know very little about either. Asking for your thoughts on each, and any proposal for an alternative is welcome.
Thanks,
View tomsteve's profile
tomsteve
808 posts in 1336 days
#1 posted 11-16-2017 04:26 PM
fast shiney finish= lacquer.
personally i use BLO on ornaments, but its not fast.
View Notw's profile
Notw
662 posts in 1870 days
#2 posted 11-16-2017 04:29 PM
In my experience lacquer takes more than one coat to get a shiny fininsh, but you can recoat in 30 minutes
View Dustin's profile
Dustin
551 posts in 857 days
#3 posted 11-16-2017 08:01 PM
Shine juice? Equal parts of dewaxed shellac (2# cut), denatured alcohol, and boiled linseed oil. Might take a couple of coats, but goes on and recoats very quickly, from what I’ve read (haven’t tried it myself yet).
-- "Ladies, if your husband says he'll get to it, he'll get to it. No need to remind him about it every 6 months."
View OSU55's profile (online now)
OSU55
1831 posts in 2106 days
#4 posted 11-17-2017 05:58 PM
I use CA glue for a glossy finish on small dia stuff like ornaments
View Hockey's profile
Hockey
138 posts in 529 days
#5 posted 11-18-2017 01:33 AM
I like using a friction finish. I use Hut Crystal Coat. It’s fast and easy.
View Lazyman's profile
Lazyman
2386 posts in 1504 days
#6 posted 11-18-2017 05:18 AM
I’ve had good results using either the Hut friction finish or a CA finish. The Hut finish is quicker and easier because it require fewer coats and fewer steps but is not quite as shiney as the CA can be. A spray lacquer will give you a nice shiney finish but it takes time to dry between coats whereas both the CA & Friction finish are done when you take them off the lathe.
