How to test for moisture content
Forum topic by amateur posted 02-21-2011 12:23 PM 9768 views 0 times favorited 13 replies Add to Favorites Watch
View amateur's profile
amateur
91 posts in 2681 days
02-21-2011 12:23 PM
I have a slab of ash drying in my garage shop. It was cut about two years ago. Measures 44” x 3” x 72”. When can I begin to think about using it and is there any way of testing moisture content without a meter? I don’t want to jump the gun, but I hear it calling my name. If it is still too wet, practical suggestions on speeding up the dry time would be appreciated. Thanks.
13 replies so far
View Bill Davis's profile
Bill Davis
226 posts in 3948 days
#1 posted 02-21-2011 01:40 PM
Yes you can find the moisture content without a moisture meter.
What you need:
A sample piece of the wood cut from the center of a representative board that weighs approx 100gm,
An accurate scale capable of weighing the piece to the nearest 0.1 gm.
A small toaster oven that can be set to run at 212degF continuously i.e. not on a timer.
Procedure:
Weigh the piece of wood to the nearest 0.1gm.
Put the piece of wood into the oven and set the temperature to 212 deg F.
After 24 hours weigh the piece again.
Put the piece back into the oven for one more hour.
Weigh the piece again. If it weighs less than the last measurement put it back into the oven for another hour.
Weigh it again. Repeat this process untill the weight remains the same as the previous weight. That is the oven dry weight.
Now take the original weight and divide it by the oven dry weight. Subtract 1. Multiply the result by 100. The resulting number is the moisture content of the original piece of wood.
Or just get a moisture meter.
If moisture content matters, and it does, then you should have a moisture meter and use it in your shop. How much have you paid for your other tools? It has been said that 90% of all problems with wood are related to moisture. Isnt it worth $100-$200 to have one?
View cranesgonewild's profile
cranesgonewild
344 posts in 2932 days
#2 posted 02-21-2011 04:32 PM
Hey Bill, what moisture meters would you recommend?
I need one as well.
-- I'm a Fungi --
View Nomad62's profile
Nomad62
726 posts in 2982 days
#3 posted 02-21-2011 06:37 PM
I would think it useable by now provided your garage shop is heated. You could take a slice about an inch thick from the edge and put it in your house for a month and see if it moves; if it stays straight you should be just fine. If it warps, twists, whatever (after drying, not right away) then it may require more time.
View Scsmith42's profile
Scsmith42
125 posts in 2701 days
#4 posted 02-22-2011 04:12 AM
RE moisture meters, most kiln operators use meters by Delmhorst, such as the J2000. For a professional grade RF type meter, look into the Merlin’s.
-- Scott, North Carolina, www.quartersawnoak.com
117115 posts in 3601 days
#5 posted 02-22-2011 04:23 AM
Here are the moisture meters I suggest.
http://wagnermeters.com/woodworking.php?gclid=CNDvq__ZmqcCFUMUKgodNQfn2g
I own the L606 and have found it to be very accurate and very sensitive .
View bhog's profile
bhog
2236 posts in 2714 days
#6 posted 02-22-2011 04:40 AM
I have never owned a moisture meter and possibly never will.Heres how I was taught and what I do ;sweep off dust etc from the piece in question ,touch your fingure (lightly)to your tongue and streak it on the wood.start counting how long it takes to disappear if it is less than 6 seconds I will use it,if not it needs more drying. Now I realize that way is not scientific or as accurate as a moisture meter,but it comes from a time when they didnt have em.
-- I don't drive a Prius.
View reberly's profile
reberly
191 posts in 2713 days
#7 posted 02-22-2011 04:20 PM
I have at least 3 moisture meters. Between the Wagner pinless and the lignomat, my favorite is the Lignomat DX. It is the most accurate from my experience.
Rich
-- "Big Timber is our Legacy" , http://eberlywoods.com
View Barbara Gill's profile
Barbara Gill
153 posts in 2684 days
#8 posted 02-22-2011 08:13 PM
You don’t say if you plan to resaw or use the piece as is. Unless pinless moisture meters have improved they only measure around 1” deep. So the center inch would go unmeasured. If you use a moisture meter with pins you need to either drive it into the middle of the board or drill holes. Either way you have damaged the piece.
I can’t think of any way you can determine the moisture content with confidence without compromising the slab.
-- Barbara
#9 posted 02-22-2011 08:30 PM
Hi Barbara welcome to LJs
I don’t know about other pinless moisture meters but when ever I’ve tested mine next to a pin type meter and I’ve found my meter to be maybe even more accurate so much in that on a 3” thick piece of wood if you have your hand under the wood where you reading the meter,it changes the reading showing moisture in my hand increasing the moisture reading on the meter.
Barbara Gill
#10 posted 02-22-2011 11:13 PM
Hi Jim thanks. Wow, it appears that pinless moisture meters have come a long way!
-- Barbara
View SASmith               's profile
SASmith
1850 posts in 3011 days
#11 posted 02-22-2011 11:38 PM
Here is a good diy moisture meter from a simple multimeter by Matthias Wandel. Also check out the rest of his site if you have never been.
http://woodgears.ca/lumber/moisture_meter.html
-- Scott Smith, Southern Illinois
amateur
#12 posted 02-23-2011 01:44 AM
Thanks for the input everyone. I tried the wet finger test, Brandon, and it took a little longer than 6 seconds. In the end, I will use a meter. My plans for a live-edge desk for my home office depend on accuracy. Impatience has been my greatest woodworking nemesis. Guess I’ll take a deep breath and dive into a couple of the other ten million projects I’ve always wanted to do.
View Dave's profile
Dave
11429 posts in 2864 days
#13 posted 02-23-2011 03:17 AM
Bill now i got a head ache. Do you have to do all that standing on one foot. Buy a meter.
