Hook And Loop
Forum topic by ChunkyC posted 02-21-2011 05:53 AM 965 views 0 times favorited 5 replies Add to Favorites Watch
View ChunkyC's profile
ChunkyC
856 posts in 3159 days
02-21-2011 05:53 AM
Anyone know of a source for Hook Loop? I want to make a sanding block that uses the same 5” round H&L paper as my ROS. I assume that not all H&L is created equal??
Thanks,
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
5 replies so far
View lew's profile
lew
11941 posts in 3660 days
#1 posted 02-21-2011 07:30 AM
Try these folks http://www.supergrit.com/
View dbhost's profile
dbhost
5686 posts in 3137 days
#2 posted 02-21-2011 07:33 AM
Try WalMart in the craft section. Look for a product called “Velcro”.
All smart aleckyness aside…. I think hook and loop is more or less intercompatible, You just need loopy material on one side, and hooky material on the other. (Love those technical terms don’t ya?). I have has the misfortune of having velcro loose in a box with some H&L sanding pads, and they sure did grab no problem!
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View docholladay's profile
docholladay
1287 posts in 2964 days
#3 posted 02-21-2011 11:50 AM
At Home Depot, they sell a self adhesive H&L pad that is designed to us on sanders that were not initially equipped for H&L. The adhesive on it is tough. You could take a block of wood, put one of those on there a bingo, you have an instant block sander. You, sir, have give me an idea.
Thanks,
Doc
-- Hey, woodworking ain't brain surgery. Just do something and keep trying till you get it. Doc
View HorizontalMike's profile
HorizontalMike
7747 posts in 2819 days
#4 posted 02-21-2011 04:54 PM
The only thing I would add is that the adhesive is strong enough to pull the finish off of some poorly finished wood blocks, thus ruining the velcro. IMO, the finish on your block should have many more coats than normal and be well cured. My 2-cents…
View bigike's profile
bigike
4053 posts in 3193 days
#5 posted 02-21-2011 06:24 PM
try http://www.woodworkingshop.com/ I know they have it. What your looking for is a kling on conversion kit
they have a sheet 12”x24” for about $15.00 good luck!
