| Forum topic by mzimmers | posted 820 days ago | 1157 views | 0 times favorited | 11 replies | ![]() |
820 days ago |
Hi, all - I just invested in a router table. One of the things I’d like to do is use it for cutting profiles into the ends of boards (such as for glue joints). What’s the best way to do this? Miter gauge and some clamps to hold the workpiece to the clamp? Thanks for any suggestions. -- M. Zimmers, central CA |
11 replies so far
#1 posted 820 days ago |
I think you’re talking about routing across the grain. If so, the biggest suggestion I can make is to alway use a backer board. Follow the board you’re routing tightly with another board. I usually use a scrap piece just in case. If you don’t, routing across the grain, when you get to the edge, it tears out easily. Sometimes so bad that it looks more like a blowout than a tearout. |
#2 posted 820 days ago |
Thanks, William. Yes, I was referring to routing across the grain. The real challenge is that I may want to do this to some pretty narrow boards. How do you suggest I keep the workpiece at 90° to the fence? That’s why I was asking about a miter gauge with a wood extension on it, then clamping the workpiece to the extension. I could use this method with the backer board as you suggest. I was just wondering if there were any slick setups for doing this, and/or if I’m not using the right tool(s) for this kind of work. Thanks again. -- M. Zimmers, central CA |
#3 posted 820 days ago |
I use a jig I made in a “T” shape. The “top” of the T is offset from the upright part and is used to slide along the front edge of the router table, which then keeps the upright part of the T 90 degrees to your fence. Of course, I don’t use the fence with this, just put the piece to be routed up against the T and slide it from right to left. I cut most of my tenons this way. You can use a backer board with this too. I may have to get you a picture later so it makes sense. -- Dale Manning, Carthage, NY |
#4 posted 820 days ago |
Hey, Dale - Pics are always nice, but I think I get what you’re talking about. I probably should have mentioned that this is the table I bought: http://www.sears.com/shc/s/p_10153_12605_00961181000P?mv=rr#specs As you can (hopefully) see, it has a 3/4” track running the width of the table. This is why I was thinking of some kind of miter gauge. Two questions about your set-up: 1. do you clamp the workpiece to your jig? If not, how do you prevent the workpiece from getting a mind of its own and jumping out of your hand? 2. if you don’t use your fence, how do you know where to position your workpiece so that the cut is of the correct depth? Thanks. PS: I really don’t mind spending a little money on this, if it will take some of the guesswork and risk out of doing these cuts, which appear to be a bit tricky. -- M. Zimmers, central CA |
#5 posted 820 days ago |
It would probably be good to clamp several together since they are narrow. If you make the backer board wide enough it should keep things square. -- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford |
#6 posted 820 days ago |
Sounds like a job for a coping sled. You can buy or make your own. A backer board should be used too. |
#7 posted 820 days ago |
OK, thanks, Lynn. So…any recommendations for a miter gauge? It has to have a face that’s not too deep, otherwise it will come too close to the router bit, and I have to leave room for clamping. I assume that traditional C clamps are right for this? Any brand recommendations here? -- M. Zimmers, central CA |
#8 posted 820 days ago |
I never use a miter gauge. Just make sure the backer board is wide, like 6-8” and 10-12” long with your pieces clamped to it. If you use the fence it will keep things square. I like to use the jorgensen deep engagement clamps for something like this. -- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford |
#9 posted 820 days ago |
Here are the pictures of the jig I mentioned earlier. I do have an adjustable stop which answers your question of what I do without the fence. You can see how I use it to make the tenons. I make a couple passes, nibbling away at it, with the last pass being the one with the piece up against the stop. It is very rough, because I used scrap that I had laying around, threw it together really quick to see if it would work, and haven’t changed it since I made it six years ago. I also have another router table now, but still use this with the router I mount to the underside of my workbench. I’ll be happy to answer any more questions about it. I didn’t come up with this idea. I saw a picture of one years ago somewhere.
#10 posted 820 days ago |
Thanks for all the help, everyone. Chuck: I think you may be right that the coping sled is most appropriate for what I’m doing. Any brand recommendations? The Infinity looks appealing because it has an adapter bar that should work with the 3/4” slot in my table top. I’m open to other suggestions, though. This is something I really would like to do right. Thanks again for all the assistance. -- M. Zimmers, central CA |
#11 posted 820 days ago |
The table you said you have is real similar th Ryobi one I’m currently using. If so, the problem with the miter guage us the slot that is in the table. It is with mine anyway. Mine came with a miter guage that is so sloppy in the slot that I may as well do it freehand. I had a miter guage I had made for a project a long time ago. I wish I had photos for you, but it got dropped and broke long time ago too. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
