Sander/Carpel Tunnel
Forum topic by Jahness posted 02-20-2011 10:52 PM 1951 views 0 times favorited 17 replies Add to Favorites Watch
View Jahness's profile
Jahness
70 posts in 3001 days
02-20-2011 10:52 PM
Topic tags/keywords: sander
I’ve been using a porter cable ROS for several years now and now it’s starting to leave me in pain and discomfort. Is there anyone else with Carpel Tunnel and if so, what sander/brand do you use that dosen’t leave you in pain and discomfort?
Thanks
-- John
17 replies so far
View Blue Mountain Woods's profile
Blue Mountain Woods
110 posts in 3171 days
#1 posted 02-20-2011 11:46 PM
+1 to Skarp. My hands buzzed for years with Bosch, Makita and DeWalt. About 2 years ago, I bought a Festool RO 150 EQ. It made a huge difference, not only in my hands, but in the sand.
-- Pete ----- http://www.bluemountainwoods.com
View artthruwood's profile
artthruwood
28 posts in 2999 days
#2 posted 02-21-2011 03:11 AM
I know the feeling at work we have pneumatic ROS palm sanders and you have to keep them turned on with your palm while holding them and after a few mins they kill. I just developed different ways to hold it and still apply pressure to sort of ease the pain on my hand. try that maybe?
-- slowing down with bring you greater speed then going fast
View Gpaw's profile
Gpaw
65 posts in 2925 days
#3 posted 02-21-2011 03:38 AM
I just started using an air sander—its an Ingersoll-Rand IR 4151 6 Inch Random Orbit Finishing Sander.
it is not loud , it stops fast and you can power sand when you need it . it is smooth.
I like it so much I bought two one with HL pad the other PS pad so when I catch paper on sale I can use whats on sale.
Jahness
#4 posted 02-21-2011 05:15 AM
Thanks for ideas, but, Festool is way out of my reach right now. Air sander won’t work too well since they use alot of cfm’s and my little compressor won’t hold up. I’ve been using anti vibration gloves for several years but I guess my CPS is just too far gone. I guess I was just hoping to find a brand out there that’s not too expensive and dosen’t vibrate to much.
Thanks for the above comments
-- John
View SnowyRiver's profile
SnowyRiver
51457 posts in 3718 days
#5 posted 02-21-2011 04:59 PM
I have a PC, Bosch, and Makita ROS. I find that the ones where my hand is directly over the motor are the most comfortable vs the ones that have a barrel motor and the handle off the side. I find the barrel motor type tires my wrist.
-- Wayne - Plymouth MN
View Loren's profile
10477 posts in 3885 days
#6 posted 02-21-2011 06:36 PM
I used to often hold orbital sanders by the strain reliever. You’re not
supposed to apply pressure, the weight of the sander is sufficient and
you’ll wear it out if you press on it.
I have Festool barrel-grip sanders now but I still steer them by the cord
too. They are the best I’ve used but my hands still go numb when I
do a lot of sanding with them.
The Bosch 6” dual mode sanders are very similar to the Festool and much
less money to buy. I’m not saying they are the same, but they allegedly
come out of the same factory and it’s clear from looking at them that
they share many design characteristics.
View Vicki's profile
Vicki
1106 posts in 3582 days
#7 posted 02-22-2011 07:10 PM
Have you had surgery yet? Surgery corrected mine and now I use all my sanders without problems. PC Random Orbit, Makita 1/4 sheet sander, Dremel Multimax.
Maybe check out some of the Duragrit products. I think they are supposed to be more aggressive and get the job done sooner?
Vicki
-- Vicki on the Eastern Shore of MD
Jahness
#8 posted 02-23-2011 04:12 AM
No, I rejected the surgery at the time cause a friend’s wife had it done and they totally botched one of her wrist. Took 2 years for her to go back to work. Today I used it with my speed control from my Router Table and that seemed a little better, but not enough for comfort.
-- John
Vicki
#9 posted 02-23-2011 04:49 AM
I understand. Try using a ‘cock-up splint’, wearing it to bed every night and take Motrin before sanding. Just a thought. I’m a nurse so always trying to fix things. If I’ve crossed a line, I’m sorry. Also, there should be other ortho surgeons in your area. Keep looking until you find one everyone speaks highly of.
View Steve2's profile
Steve2
75 posts in 3808 days
#10 posted 02-23-2011 06:22 AM
I am sitting here with bandaged wrist after carpal surgery last week. If you think you have carpal – v. normal vibration irritation – see a neurologist ASAP and plan on something more scientific than guessing/swapping brands. The neurologist can test, maybe an EMG, and decide if necessary to see an orthopedist, depending largely on insurance provisions. Vicki suggests a splint which may or may not be appropriate for your condition – don’t make that decision by yourself. You might be too late for a splint – I was.
Sorry to say this, but I got rid of my various sanders because of the vibration and racket and now have a full Festool lineup as to that question.
-- Regards, Steve2
View Scott Gilroy's profile
Scott Gilroy
45 posts in 3239 days
#11 posted 02-23-2011 07:39 AM
Here’s my 2 cents. I’m an Occupational Therapist and agree that you should see a neuro or ortho. They will do some tests to determine the cause and severity of your problem. They will likely do a Tinels Sign and Phalen’s test, which are very simple tests to gather some basic info. Do other activities cause numbness and/or pain? Make sure you are not gripping the sander too tightly, as this may also cause these symptoms. The position of your grasp will make a difference too. I would try the anti-vibration gloves and as mentioned in previous response, you shouldn’t be applying any pressure to the sander-only guide it in the direction you want to go.
Don’t forget to call the MD, then get a second opinion. Good luck.
Funny thing is I’ve seen these for the first time a few hours ago on the Highland WW site. I’ve heard of them, but never saw them before this evening. May be worth a try for about $17.00, especially if you don’t get any symptoms at other times.
-- Scott
Jahness
#12 posted 02-23-2011 07:55 AM
Again, thanks to all. Yes, I did see a Neurologist at the time when I had insurance and he had me try different hand and wrist exercises as well as a wrist splint but now the splint just irritates it more. The gloves worked years ago but I’ve gotten worst now so they do little for me. No Vicki, you didn’t cross a line. I appreciate ALL advice and comments. I guess I’m just going to have to figure something else out for now.
Thanks Again
-- John
Vicki
#13 posted 02-23-2011 09:26 AM
One last thought then. Before I had my ROS I used a 1/4 sheet sander for many years. It did as well, just needed to remember not to go in circles. It was smaller and lighter and never bothered my wrist.
View Viktor's profile
Viktor
466 posts in 3656 days
#14 posted 02-23-2011 10:00 AM
I hold ROS at the base with three fingers and wrist not even touching it. Much better balance and control without any discomfort regardless of the brand. I second what Loren said about applying pressure.
View depictureboy's profile
depictureboy
420 posts in 3880 days
#15 posted 02-23-2011 02:22 PM
I use trigger point therapy to keep mine under control, my wrists were bad from several years of keyboarding, but now I dont have any problems(knock on wood) and I have actually been keyboarding more. Sometimes I get the numbness, but its from posture or pressure on my elbows…if I start to get the twinge I start massaging the TPs and the pain subsides…I keep up the massaging over a couple days and I am back to normal…
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
