Flat Surface for Restoring Hand Planes
Forum topic by pete79 posted 02-20-2011 03:57 PM 4551 views 0 times favorited 18 replies Add to Favorites Watch
View pete79's profile
pete79
154 posts in 3164 days
02-20-2011 03:57 PM
Topic tags/keywords: refurbishing sharpening
Hey all -
So I’m venturing into the world of restoring hand planes for my use instead of buying new ones (for now).....http://lumberjocks.com/topics/24609
So now i’m at the point where i need to get set up to begin the process. I have all the supplies that i need for the process (I think). My question is what is a suitable flat surface to tape/stick my sandpaper to for flattening the bottoms of the planes? I’m trying to go the lowest cost route that will still produce a very good result. I’d prefer not to have to run out and buy a small slab of granite, and I’m not fond of the idea of taping/sticking the sandpaper to my table saw top. I’d like to set up a dedicated area/surface for this purpose. A couple ideas I have are as follows – i’m not sure if these are adequate:
1. MDF – I have a lot laying around and it seems to be perfectly flat – is there something i’m missing here?
2. Granite tiles glued together with epoxy and glued down to MDF – seems like a suitable idea as long as i’m sure the two tiles are level with each other? This seems a lot cheaper than buying small slab of granite, but a step up from just MDF – is this necessary?
Any others that people are using that don’t cost too much?
-- Life is a one lap race.
18 replies so far
View HorizontalMike's profile
HorizontalMike
7758 posts in 2937 days
#1 posted 02-20-2011 04:08 PM
I bought a <$4.50 black Granite flooring tile from HD. Holds a full sheet with extra space on all sides. Works great. Not sure if trying to use two next to each other is worth the hassle/headache, IMO.
View chrisstef's profile (online now)
chrisstef
17423 posts in 3029 days
#2 posted 02-20-2011 04:11 PM
I use a scrap piece of laminated safety glass, got it for nothin from the local glass company. If you are using a honing guide the little wheel may indent the MDF over time.
I just spent 5 hours yesterday sharpening 6 plane irons and now i have a bald patch on my arm … sharp enough for me!
View SergioC's profile
SergioC
82 posts in 2690 days
#3 posted 02-20-2011 04:11 PM
Granite tiles are available in decent sizes where you wouldn’t need to glue several together. I wouldn’t use multiple surfaces. You would have to level the tiles to each other (like laying tile) but they would need to be perfect. I just saw 18”x18” granite tiles for under 10 bucks online from several places.
View Lee Barker's profile
Lee Barker
2170 posts in 2873 days
#4 posted 02-20-2011 04:11 PM
MDF can be pretty darn flat. And you can work with it, being a woodworker. The thicker the better.
Granite pieces seem to be pretty easy to come by in our corner of the country, but to my surprise I’ve found some that weren’t flat. Can’t explain that. So don’t, as they say, assume.
Kindly,
View knotscott's profile
knotscott
8055 posts in 3399 days
#5 posted 02-20-2011 04:19 PM
MDF can be very flat, but it’s not overly strong and needs support. I’d put the sandpaper on MDF, then set the MDF on your TS as a substraight….keeps your saw clean but you still benefit from the flat surface. You can even put a cleat on one end of the MDF to help keep it in place.
View richgreer's profile
richgreer
4541 posts in 3098 days
#6 posted 02-20-2011 04:38 PM
Plate glass costs $6.00 per square foot. I bought a 1’ by 2’ piece and mounted it on a piece of plywood. Works great.
View poopiekat's profile
poopiekat
4356 posts in 3757 days
#7 posted 02-20-2011 04:46 PM
I use the tempered glass insert, approx 24” X 28”, from an old aluminum storm door. It was the only part that survived when the door was blown off in high winds. Nice aluminum frame with a ridge that butts perfectly against the workbench, too! And it was free!
pete79
#8 posted 02-20-2011 05:51 PM
Imagine my surprise an hour ago when looking for something completely unrelated in the basement I came across a 1/4” thick, 4’x2’ piece of plate glass from an old table my parents gave us 8 years ago! We threw the bases of the tables out (wicked ugly) and kept the glass. My wife always said “what are you going to do with that, you should throw it out”. Well for once, keeping something pays off!
View davidroberts's profile
davidroberts
1027 posts in 3509 days
#9 posted 02-20-2011 06:36 PM
I caught a sale last month on this granite plate for $19.95. I was shocked at the quality and weight. I believe if anyone is serious about sharpening and flattening over the long term, this is a good deal even at the standard price of $31. By the way, the surface is certified dead flat. I mean absolutely dead flat.
http://www.woodcraft.com/Product/2004864/7535/Granite-Surface-Plate.aspx
-- Better woodworking through old hand tools.
View rance's profile
rance
4258 posts in 3183 days
#10 posted 02-20-2011 07:55 PM
David, Did you notice the nice data sheet that comes with it that tells you how flat it checked out to be? A half a thou. high in the upper left corner, a quarter of a thou. high on the lower right corner… Well, I opened another box to compare. Low and behold, it said the EXACT SAME THING. I’m not saying that these are not useful for flattening a plane, they are VERY useful, I still recommend them, but I would not put much stock in the included data sheet.
View wb8nbs's profile
wb8nbs
164 posts in 2715 days
#11 posted 02-20-2011 07:57 PM
I use a couple of glass shelves from a garage sale.
I have a Frank Klaus video where he uses a slab of melamine covered particle board. Doubt if you can beat the price.
-- The only difference between men and boys is the price of their toys.
View bigike's profile
bigike
4052 posts in 3311 days
#12 posted 02-20-2011 08:11 PM
I went to a place where they sell counter tops and floors that are made from marble granite that type of thing and asked for a piece about 24”x24” and they gave me a piece about 3”x 24” not my measurments I gave but the thing is they gave it to me for free the only draw back was the sides were not smooth but he did ask if I needed them smooth I said no so you get what you ask for sort of.
View canadianchips's profile
canadianchips
2602 posts in 3020 days
#13 posted 02-20-2011 08:25 PM
I use tempered glass from an oven door that was no longer used. 1/4” plate glass.
View Lochlainn1066's profile
Lochlainn1066
138 posts in 2800 days
#14 posted 02-20-2011 11:01 PM
I got 2 granite sink shaped cutouts from a local installer. The shape isn’t ideal but they were free.
-- Nate, thegaragestudio.etsy.com
View Bill White's profile
Bill White
4948 posts in 3983 days
#15 posted 02-22-2011 06:08 PM
The float glass (that’s what everybody is meaning when they say “plate” glass) is as good as you will ever need for plane irons or soles. If you can scarf up a piece of safety float-go to local glass company-you’ll be ahead of the game.
Bill
-- bill@magraphics.us
