Reversing the JET 1014VS lathe
Forum topic by RetiredCoastie posted 02-20-2011 09:19 AM 2019 views 0 times favorited 0 replies Add to Favorites Watch
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3204 days
02-20-2011 09:19 AM
Just before Christmas my lathe speed controller died on my JET mini lathe. I finally got a replacement circuit board and got it installed. While waiting for the board to come in I stumbled across this website:
http://www.frontrangewoodturners.org/misc_pdf/reversing_the_jet.pdf
which tells how to add a reversing switch to the JET 1014VS lathe. I just completed adding the switch and it works like a charm, I can now reverse turn and sand which does give a really smooth finish. The switch is easy to install and only takes about 2 hours of time and less than $10.00. Just follow the instructions on the website and you’ve increased the functionality of you lathe. I believe this will work on all lathes that use a DC motor. All your doing is reversing the polarity of the motor.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
0 replies so far
