Hand Plane I.D. Help
Forum topic by MOJOE posted 02-20-2011 05:24 AM 1475 views 0 times favorited 4 replies Add to Favorites Watch
View MOJOE's profile
MOJOE
548 posts in 3292 days
02-20-2011 05:24 AM
My father-in-law sent a No. 4 bench plane my way this evening. It was his father’s, and I am wondering if I can get some help id-ing the tool. The only marks on the plane are “made in the usa” behind the front knob and a “U” stamped into the underside of the cap iron. The plande body is blue and the frog is yellow. Also, the lateral adjustment lever is flat steel with a 90-degree twist at the end for your finger and thumb. The tote and know appear to have been painted black at one time…..any ideas???? Sorry no pictures yet, just got home.
joe
-- Measuring twice and cutting once only works if you read the tape correctly!
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3736 days
#1 posted 03-14-2011 03:57 AM
Joe have you been able to take some picture yet?
MOJOE
#2 posted 03-14-2011 04:11 AM
http://lumberjocks.com/MOJOE/blog/21486
Mark,
I posted the pics in a second blog posting…...at first, folks thought it was a “frankenplane” made up of different components, but them someone tipped us off and let us know it is likely a Stanley two-tone…..
View knotscott's profile
knotscott
8055 posts in 3399 days
#3 posted 03-14-2011 02:10 PM
Joe – There are several indications that this plane is on the older side, but I could be wrong. Based on the info on Rexmill.com, the lack of a support ring around the front knob indicates type 13 or older (pre 1928). The square corners of the blade, solid cast y-adjuster for the depth knob, and key hole shape, are other indicators of age. I’m far from an expert but it’s possible that some things were painted by an owner/user at some point.
MOJOE
#4 posted 03-15-2011 01:13 AM
garyp…...looks exactly like the planes 3-6 on the roseantiquetools site…...thanks
