Router bits
Forum topic by richardchaos posted 11-12-2017 01:43 PM 533 views 0 times favorited 9 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 583 days
11-12-2017 01:43 PM
Does anyone have any opinion on Yonico router bits. I have seen some comments on Amazon I find hard to believe. Such as them exploding apart and a 1/2 shaft bending…
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
9 replies so far
View splintergroup's profile
splintergroup
2429 posts in 1426 days
#1 posted 11-12-2017 02:58 PM
I own two including a rather large lock mortice bit.
I bought the mortice bit with the assumption I would only need it rarely, but I’ve been using it more than I had intended.
Cut is reasonable and construction (no crappy brazing of the carbide, poor machining, etc.) to be found.
I think they fit the “you get what you pay for” adage, reasonable quality at a reasonable price.
Good QC is the responsibility of the manufacturer. These import bits probably don’t get a very rigorous screening and more turds will slip through then say with Whiteside bits. Inspect closely and if all look good, the bits will do their duty.
A bent shaft is easy enough to do if the bit gets caught and throws a part, though I’d guess the Yonico bits don’t use the best tool steel.
117340 posts in 3781 days
#2 posted 11-12-2017 03:25 PM
I’ve never used them but have I purchased 80 pieces set low-cost router bit set from eBay and recommended them to a dozen or so students that have never had a problem with them.
https://www.ebay.com/itm/80pc-1-2-Shank-Tungsten-Carbide-Router-Bit-Set-3-Blade-Power-Tools-Accessories/311668116807?epid=1979964770&hash=item4890de0d47:g:yhIAAOSwtnpXn8Zc
richardchaos
#3 posted 11-12-2017 05:23 PM
This is an image send in on a comment on Amazon. Its hard to believe!
richardchaos
#4 posted 11-12-2017 05:24 PM
Also hard to buy this guy has the money for a festal router but cheaps out on the bits!
View AlaskaGuy's profile
AlaskaGuy
4811 posts in 2513 days
#5 posted 11-12-2017 05:34 PM
Why in the world would you not just stick with the name brand bits that have proven themselves over and over.
View Loren's profile
10477 posts in 3852 days
#6 posted 11-12-2017 06:03 PM
I wouldn’t personally stack a bunch of slot
cutter bits on a 1/4” shank. The user was
may have been trying to cut a big rabbet topside
in one pass. Those slot cutters usually only
come with one bearing for a fairly deep cut.
That’s just a dumb setup.
View Redoak49's profile
Redoak49
3670 posts in 2192 days
#7 posted 11-12-2017 06:44 PM
I had one of the Yonico bits and it was OK but used it on stuff where I knew I could hit something. I normally buy just Freud or Whiteside bits.
Secondly, I use primarily 1/2” thanks. Only 1/4” thanks for small diameter bits.
woodbutcherbynight
5720 posts in 2613 days
#8 posted 11-12-2017 11:59 PM
I have them but only in 1/2 shank. Never had an issue and like others thought I would use them on a rare occasion and instead use them more often. To date none of the 9 I own have had any issues. Use them for most generic projects. For that rare masterpiece I have some whiteside ones I would use.
I use 1/4 shank for my small trim router. These are small diameter bits for roundovers and such.
View SuperCubber's profile
SuperCubber
1043 posts in 2488 days
#9 posted 11-13-2017 12:16 AM
I have a handful, generally, ones I don’t use frequently.
I have had a bearing come loose though. It started making a crazy noise, so I was able to shut the router off before it caused any project or tool damage. Otherwise, they’ve been fine. Not the best, not the worst.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
