please help me not screw this up - mitre station - chime in
Forum topic by Upgrayedd posted 11-12-2017 01:42 PM 3189 views 0 times favorited 17 replies Add to Favorites Watch
View Upgrayedd's profile
Upgrayedd
94 posts in 1299 days
11-12-2017 01:42 PM
May be an impossible request, but specifically:
Should I butt the wings up to the saw platform as in picture #1 below.
or just build boxes, as below in picture #2?
(I’m going to put a 36” T Track on, so the top is 36”, and I’ll build the bottom as nec.)
-- Upgrayedd - spelled thusly, with two Ds, for a double dose of this pimping.
17 replies so far
View richardchaos's profile
richardchaos
583 posts in 496 days
#1 posted 11-12-2017 02:05 PM
I say standoff like #2… LOL I said NUMBER TWO!
-- ā€œIn a time of universal deceit, telling the truth is a revolutionary act.ā€ ā€• George Orwell
View Manitario's profile
Manitario
2631 posts in 3000 days
#2 posted 11-12-2017 03:53 PM
Doesn’t matter which way you do it, as long as the wings are level with the top of the MS.
View sras's profile
sras
4871 posts in 3246 days
#3 posted 11-12-2017 04:15 PM
The second one will be easier to clean up around the saw.
Upgrayedd
#4 posted 11-12-2017 04:31 PM
Thanks guys… I also like the 2nd better, but when i showed my brother, he was emphatic on the first option.
Both will work, but I just think it’s cleaner look in 2nd option, and no drop off on use ability
View tmasondarnell's profile
tmasondarnell
97 posts in 1906 days
#5 posted 11-12-2017 06:05 PM
The other advantage of #2 is that if you change saws, you have more flexibility.
Upgrayedd
#6 posted 11-12-2017 07:10 PM
Excellent point.
View pete724's profile
pete724
68 posts in 926 days
#7 posted 11-18-2017 09:44 AM
In #1 when you miter the saw all the way does it hit the wing??
if mitered all the way and then the saw slides out, does it then hit??
View Gene Howe's profile
Gene Howe
10826 posts in 3545 days
#8 posted 11-18-2017 12:12 PM
- tmasondarnell
Absolutely. VOE.
Although, bsk84 (above) makes some good points. :-)
Craftsman on the lake
2804 posts in 3555 days
#9 posted 11-18-2017 12:23 PM
Either way is okay . No 2 will not be a problem. The gap won’t affect cutting.
View pontic's profile
pontic
626 posts in 725 days
#10 posted 11-18-2017 01:35 PM
Howcome everyone of the “chopshelfs” under construction I’ve seen here lately are being constructed without an adjustment system for the saw mounting platform? I know everyone says shims but I think that is a pain. Wood moves even plywood and eventually an adjustment will be needed to make the saw true to the fence once again.
-- Illigitimii non carburundum sum
Upgrayedd
#11 posted 11-18-2017 03:48 PM
Howcome everyone of the “chopshelfs” under construction I ve seen here lately are being constructed without an adjustment system for the saw mounting platform? I know everyone says shims but I think that is a pain. Wood moves even plywood and eventually an adjustment will be needed to make the saw true to the fence once again.
- pontic
To be honest I never even considered it. I’ve never seen one, but you got me thinking. What I’ve been doing for years is to shim it and move on… no worries.
My old design (link below) was ok, but I wanted cubbys under wings and saw:
http://lumberjocks.com/projects/206586
My new design uses shims as seen below, and never thought much about it… if there is a better way point me to it please! (Pointing to my shims in pic 2 – lower left corner.)
My new design considerations followed my last in that it is not permanent. I want to be able to move it easily enough if I have to, but for all intents and purposes, where it is now is where it will stay.
Example, my church flooded, and I needed to be able to bring my saw and wings to the location… my new design is fine for that.
I’ll post my new design soon… still working on it.
pontic
#12 posted 11-18-2017 05:58 PM
This is very similar to what I have
Upgrayedd
#13 posted 11-18-2017 07:06 PM
- pontic
Very nice, thanks for the input. I do believe I can make that work quite easily with what I have already.
Just use a threaded insert in the brace, correct? And do you epoxy in place?
pontic
#14 posted 11-18-2017 08:25 PM
That’s what I did.
pontic
#15 posted 11-24-2017 02:55 PM
