FWW Crossgrain glue up?
Forum topic by HTown posted 11-11-2017 05:31 AM 552 views 0 times favorited 7 replies Add to Favorites Watch
View HTown's profile
HTown
114 posts in 1271 days
11-11-2017 05:31 AM
Topic tags/keywords: fww glue joint joining
I’m looking at a small silverware tray that Christian Becksvoort featured in FWW #274 Nov/Dec 2017.
The bottom is glued from underneath directly to the sides. It seems like this would create a cross grain situation that would fail due to differential expansion.
Can anybody explain why this joint wouldn’t fail?
Please don’t take this as a critique of CB’s design, I really admire his woodworking and journalism. Here is a link in case you missed the article:
http://www.finewoodworking.com/2017/09/27/four-handmade-gift-ideas
Thanks.
7 replies so far
View Loren's profile
10477 posts in 3733 days
#1 posted 11-11-2017 05:58 AM
He mentions using quartersawn pine. Quartersawn
wood moves less. It’s a risk he’s willing to take
apparently on a small box.
A few months back there was a discussion here on
making chessboards where examples were shown
that took risks with wood movement but hadn’t
had any problems. I believe there were also
some examples of failures.
View Andre's profile
Andre
1960 posts in 1891 days
#2 posted 11-11-2017 07:06 AM
From the Pic. it looks like long grain to long grain for 2 sides so shouldn’t be a problem. Could always dowel if really concerned.
View jdh122's profile
jdh122
1032 posts in 2902 days
#3 posted 11-11-2017 11:11 AM
Quartersawn softwoods move very little (see chart http://www.finewoodworking.com/2013/08/29/calculating-for-wood-movement). A piece of QS eastern white pine 9 inches wide (seems reasonable size for an inbox) that varied seasonally from 6 to 16% moisture content would only see 6/100 of an inch movement from smallest to largest.
-- Jeremy, in the Acadian forests
View bbasiaga's profile
bbasiaga
1239 posts in 2080 days
#4 posted 11-11-2017 02:27 PM
The growth creates stress in a constrained joint. If that stress exceeds the strength of joint, it fails. A mechanical engineering type guy could tell you the strength of as cross grain glue joint and figure out how much stress gets created when the wood grows.
On a small box or tray the amount of growth is small, so perhaps the glue joint is strong enough to survive. Paul sellers made a box on YouTube recently with a cross grain glue joint. Must work on the same principle.
Brian
View TheFridge's profile
TheFridge
9867 posts in 1571 days
#5 posted 11-11-2017 04:10 PM
I have no basis for this arbitrary measurement but I keep it under 6” or less. I do it on jewelry boxes all the time and haven’t had any problems.
HTown
#6 posted 11-12-2017 02:03 AM
Thanks for the insight. I decided to go with a loose bottom for a chisel tray I’m making.
HTown
#7 posted 11-12-2017 11:37 PM
So here is the tray I was hoping to build today. More of a till to fit in a drawer. I ended up making a loose panel in grooves rather than gluing the bottom in.
I didn’t have any quartersawn material to devote to this project.
