Forum topic by RipFence | posted 11-11-2017 03:03 AM | 503 views | 0 times favorited | 12 replies | ![]() |
Just read the chapters on oil finishes and on varnishes from Understanding Wood Finishes. Really wish I had read his book years ago. SOOOOO much misleading or just plain wrong information on the web. He does a great job of giving straight facts. |
12 replies so far
#1 posted 11-11-2017 04:34 AM |
I think anyone who reads this, or any good book on finishing, is well ahead of the curve. I have this book and one by FW but the Flexner book is a better general book on finishing. I would also recommend Tage Frid’s trilogy. -- Rick M, http://thewoodknack.blogspot.com/ |
#2 posted 11-11-2017 04:34 AM |
Wait. What? Misleading information on the Internet? It can’t be. Besides his book, I never miss his regular Flexner on Finishing articles in PW. Two other good books are by Jeff Jewitt and Teri Masaschi. Along with reading, try things out. In between projects, I do countless sample boards in different woods that I use regularly and every dye, stain and finish I can get my hands on. Some of them are winners and many are definite no-goes, but it gives me a head start on where to begin when I do get to the finishing stage of a project. -- No matter how much you push the envelope, it'll still be stationery. |
#3 posted 11-11-2017 02:44 PM |
Hi Rich: Along with reading, try things out. In between projects, I do countless sample boards in different woods that I use regularly and every dye, stain and finish I can get my hands on. Some of them are winners and many are definite no-goes, but it gives me a head start on where to begin when I do get to the finishing stage of a project. |
#4 posted 11-11-2017 03:13 PM |
That’s pretty cool, Jim. What did you use for the varnish component? -- No matter how much you push the envelope, it'll still be stationery. |
#5 posted 11-11-2017 03:20 PM |
gotta get a copy! -- Jim, Houston, TX |
#6 posted 11-11-2017 03:42 PM |
Thanks Rich. I used Pratt and Lambert #38 satin varnish. What did you use for the varnish component? – Rich |
#7 posted 11-11-2017 04:02 PM |
Good choice, I just wish it was easier to find (the P&L), it’s my favorite. Flexner’s book is awesome, I read it much like a novel. Jeff Jewitt’s book is equally good, but arranged in a different fashion. I find it more useful as a esk reference when I need to check something. It’s my belief that one (or both) should be required material in any hobbyist shop…maybe a few pro shops as well. Someone mentioned this above, but Flexner writes a regular blog at the PWW site, as well as a regular column in their magazine…one of the reasons I still subscribe. -- Our village hasn't lost it's idiot, he was elected to congress. |
#8 posted 11-11-2017 04:16 PM |
I just wish it was easier to find (the P&L), it s my favorite. Thanks Fred. Based on Flexner’s discussion about protectiveness of the various finishes, I also made up a wiping varnish with two parts P & L and one part mineral spirits. It was just as easy to apply but I liked the darker color from oil. |
#9 posted 11-11-2017 04:32 PM |
Fred, uspaintsupply.com sells P&L. Their shipping rates are reasonable as well, with a $10 flat rate up to $99 and free thereafter. Jim, that should work fine. You might want to hit it with some 400 or 600 grit before the top coat. I definitely want to play around with the blends you’re doing, Jim. When I use tung oil, I usually apply it by itself, give it a few days to cure, and top it with lacquer. I also am a fan of both Waterlox original and Arm-R-Seal. They are both oil based, but give different results. Arm-R-Seal is clearer and I like that on light wood like maple, and Waterlox seems to highlight the figure more, but is a bit yellower. All are subjective though. Just my observations. I’d like to see if mixing tung oil with a high grade urethane would give me the depth of Waterlox with less color. -- No matter how much you push the envelope, it'll still be stationery. |
#10 posted 11-12-2017 12:28 PM |
Rich, thanks…I bookmarked their page. Jim, what you want to do will work fine…but why you would want to do it is a little puzzling to me. You will get the same result if you first hit the wood with a coat of BLO (or one coat of the danish oil mix), wipe it off, dry overnight, then just use the wiping varnish. The BLO (or danish oil) will provide some color/grain enhancement, then the varnish for protection. -- Our village hasn't lost it's idiot, he was elected to congress. |
#11 posted 11-12-2017 02:41 PM |
Thanks Fred! I was thinking that more coats = more protection. But, as you say, the varnish would be much more protective so maybe one coat of Danish and one coat of varnish would be the way to go.
#12 posted 11-12-2017 04:17 PM |
I have determined there are four books by Flexner (maybe more, but I quickly found four, when I include two editions of one title). The one I think might be the preferred one to get is titled “Understanding Wood Finishing: How to Select and Apply the Right Finish”, a 2010 update of the original from 1994. -- Jim, Houston, TX |
Forum | Topics |
Woodworking Skill Share
12028 |
Woodturning
2106 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4904 |
6694 |
28052 |
CNC Woodworking
211 |
Hand Tools
5407 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1388 |
Focus on the Workspace
2154 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
