dust collection for top of band saw
Forum topic by rmeir posted 11-10-2017 10:43 AM 591 views 0 times favorited 3 replies Add to Favorites Watch
View rmeir's profile
rmeir
17 posts in 2512 days
11-10-2017 10:43 AM
I have a rikon band saw, 14 inch. I cut firewood with it since doc wnt let me split anymore. so im cutting 8 inch white oak logs which generate a lot of dust. I have a 1 hp wall mounted dust collector going into a trash can collector and it does a fine job of taking the dust from the bottom of the saw the large port. Where it leaks dust is tru the bottom quide and of course the top of the table. I rigged up the shop vac to the botom port of the saw and it does ok but doesnt effect the top of the table. Ihave searched all around and there doesnt seem to be any ideas on how to capture dust that ends up on top of the table. What I was thinking was using a splitter and one of those floor sweep thing and mounting it on the far side of the table as most dust is getting pushed that way with the log. I also am thinking of making a playwood surround for the open bottom guide are and installing a port there. All that said anyone have any other ideas on how to collect dust from the top of the table? I have seen where guys just dangle a hose from the top of the saw to the table but i wonder how effective that is. Maybe if you used a big gulp or something it might be fairly effective. but I guess you just have to try it. So if someone has a better idea or knows of a video or
article on collecting that table top dust pls let me know. During firewood season that saw will run 4 hrs aday and that a lot of dust not only sweeping up all the spillage. thanks.
3 replies so far
View Lazyman's profile
Lazyman
2707 posts in 1626 days
#1 posted 11-10-2017 11:33 AM
Four hours a day!!? Sounds like you really need a splitter. That should cut your time down to 4 hours a week at most (maybe 4 hours a month) AND eliminate your sawdust problem.
Edit: The link above is not an endorsement of brand…it’s just the first one on the search results. There are a bunch of other brands on Amazon, for example, for about the same price so you’ll want to research to find the best deal.
View Kelly's profile
Kelly
2187 posts in 3183 days
#2 posted 11-11-2017 06:47 AM
Yeah, you need a splitter.
Meanwhile, this works:
View Loren's profile
10477 posts in 3887 days
#3 posted 11-11-2017 06:57 AM
