02-19-2011 03:31 AM
Well, I hope I don’t get beat up too bad for this. Here are the results of my attempt to control the blotching on maple. I was going to order some of Charles Neil’s product but then I remembered the experience I had with shipping some water based contact adhesive in these really cold temps in the northeast. So, I looked around at what I had and tried some sealant that I had for years. It was used to seal a floor before applying self-stick tile. Well, it seems to have worked pretty well. One end of the wood in the picture was stained when I was trying to decide on a color. When I applied some MW oil stain it looked awful. I’m not sure which end it was anymore. But anyway, I applied some of the sealer to the middle and let it dry. No sanding before or after it dried but I did wet it good and wiped away the excess. I then applied stain again the next day. I have been accepting this problem for way too long. The other image is a table top that has box-store oak ply in the center and the same maple around the edges. All surfaces were treated with a 50/50 diluted mix, wetted good and wiped off the excess. I allowed it to dry overnight and then lightly sanded with 320 grit before applying the stain. After that dried for 24 hours, I applied 3 coats of water based poly. I’m not saying this is a good substitute for the stuff Charlie makes. I’ll probably get some of that when it gets warmer. He has a lot more experience at this than I do. What I am trying to show here is that there is a way to make these staining projects look a whole lot better. After spending so much time getting the wood just right, I hated what it looked like with just some light colored stain. Now I see what I was missing. I will be trying some pine projects again just to see how much better it can look.
-- Website is finally up and running....www.woodandwrite.com
12 replies so far
#1 posted 02-19-2011 05:04 PM
Dick Metz (not 100% positive that is his name) used to write a column in a cabinetmaking magazine, and he always advocated gluesize when there were stain blotching problems. This was a mixture of glue with lots of water, and you can imagine the mild sealing that that could accomplish. I am curious if any readers of this post have anything to add to that subtopic.
As for the original post, hooray for you, and I can’t see why you would want to try another commercial product when you have solved the problem. I guess we’d all want to know is this stuff cheaper, and where can one find it?
Kindly,
#2 posted 02-19-2011 05:31 PM
Cheaper for me, yes, because I had it on hand. I’m not advocating this use of the product because it is not specifically made for this use. It can still be found and at a 50/50 dilution rate it will go a long way. My intent was mainly to say that putting up with blotching is not necessary. But you will have to rethink your staining color choices. What used to seem dark will not be so dark with a blotch pre-treatment.
#3 posted 02-19-2011 05:40 PM
Lee: I have used liquid hide glue size and diluted shellac as botch and pre-stain conditioners for decades. It still works just like it has for centuries.
-- 温故知新
#4 posted 02-19-2011 05:59 PM
hobomonk, are you useing the liquid hide glue size and diluted shellac together or seperately ? And how much of a mix or dilution rate do you use?
#5 posted 02-19-2011 06:45 PM
Richard: I use the hide glue sizing and the shellac separately. I make my own finishing products, but you can use various store-bought solutions. Titebond makes a Liquid Hide Glue that can be diluted with water to use a pretreatment.
Here’s a reference on hide glue sizing: Lee Valley
Zinsser SealCoat shellac can be diluted with denatured alcohol to about a 1lb cut as a pretreatment. Mix shellac approximately one to one with the alcohol; adjust to taste.
-- 温故知新
#6 posted 02-20-2011 01:12 AM
I’ve been using Daly’s Benite under water and solvent based stains for years and it does a very good job of evening out stains.
Another thing to look into for blotch-proof coloring of woods like maple, cherry and alder is to use dyes. Either water soluble or alcohol soluble will work. Many alcohol soluble dyes are color fast and won’t fade whereas the water soluble dyes can fade when exposed to sunlight. Another nice thing about dyes is you can combine different colors to get exactly the color you want.
-- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot"
#7 posted 02-20-2011 04:01 PM
Good conversation. I must correct an error in my earlier post—Jerry Metz is his name. Carry on…I’m having lots of learnings here…
Kindly,
#8 posted 02-21-2011 07:02 PM
Lee, I remember reading Jerry Metz’s column every month. I know he was a big proponent of glue-sizing on END GRAIN, not only for protection, but also for evenness of color after staining.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
#9 posted 02-21-2011 07:33 PM
Thanks for remembering more than I did, tbone. So if you have, say, a 5 piece door with a raised panel and you want to tame the absorption on the end grain, do you size the whole piece and then sand the whole piece, leaving the sizing that’s absorbed more deeply in the end grain?
And would that same technique work on the OP’s maple? It seems like the areas that blotch on these problem woods are like end grain, occurring where the grain ceases to be parallel and more porous areas appear on the surface.
And can you make sizing from yellow glue or does it have to be hide glue?
Kindly,
#10 posted 02-21-2011 07:59 PM
D Allen There are lots of things that help with blotching some better than others. I have tried many of them and many of them are better than no treatment at all. Some I would be concerned about there long term bonding properties. Over 22 years of finishing Charles Neils blotch control worked best for me. I hadn’t heard anything about cold weather being a problem with shipping Charles products. I guess the best way to find out is to e mail Charles about it. charles@charlesneilwoodworking.com
#11 posted 02-22-2011 12:16 AM
http://www.wisnofurniturefinishing.com/2010/04/glue-size-in-wood-finish.html This seems like a pretty good explanation of glue-sizing as compared to a sanding-sealer.
#12 posted 04-03-2011 02:16 PM
I recently did the Charles Neil product….and I got to tell you it worked great….way better then I thought it or anything would…I used it to refinish a pine vanity and on some poplar and they both turn out very good.
-- Todd, Oak Ridge, TN, Hello my name is Todd and I'm a Toolholic, I bought my last tool 10 days, no 4 days, oh heck I bought a tool on the way here! †
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12028 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2106 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4904 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6694 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28056 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
212 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5407 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1419 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6232 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1388 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2154 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1186 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4756 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8845 |
