drill press table - avoiding rust
Forum topic by ribaldplaner posted 11-10-2017 01:36 AM 651 views 0 times favorited 12 replies Add to Favorites Watch
View ribaldplaner's profile
ribaldplaner
4 posts in 201 days
11-10-2017 01:36 AM
Topic tags/keywords: question drill press fence rust
Helllo!
I am a new woodworking/maker – just getting started. I’ve got a few projects under my belt and have been slowly adding tools to my shop/space. Just recently, I picked up a really nice used 15 1/2 Inch drill press (floorstanding model). It’s 40+ years old – but in really good shape. I’m really enjoying it.
How do I keep it in good shape? It’s in my garage, which I do have a dehumidifier in, but I am worried that the cast iron plate/leg will get rust on it?
Furthermore, if I build a wood fence/table for the drill press, will leaving wood resting on the cast iron table rust it out?
Any tips?
Thanks!
Tim
12 replies so far
woodbutcherbynight
4515 posts in 2403 days
#1 posted 11-10-2017 02:11 AM
I have a schedule of maintenance for such equipment in the shop. For me I lightly sand the cast iron tops and then apply paste wax and rub than in and leave it as is. On the rare occasion I see a rust spot develop repeat same before it gets too far. For the painted legs wipe them down with some car wax once in awhile and that should be enough.
Maintenance is an item I know we all hate to deal with. But even if only once a year you inspect equipment for belts, signs of wear on switches and clean everything down it will keep your equipment running without issues. Most of the time…................ Things do break but chance favors the prepared mind.
For any wood to cast iron contact I put oil based poly on the bottom, 2 -3 coats and let this dry and CURE for say 7 days then install. Again I know we all want to use it right now but letting the poly cure assures no issues later.
Every jig I have has the same treatment on the bottom.
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#2 posted 11-10-2017 04:20 AM
I used wax for years but last time I sanded down my tops, I put on a coat of waterbase poly and it is working fantastically.
View Bobthewoodbutcher's profile
Bobthewoodbutcher
22 posts in 1103 days
#3 posted 11-10-2017 04:44 AM
My Unisaw is about 30 years old and the table has zero rust. Almost the entire time it has been covered with a large sheet of heavy brown wrapping paper saturated with WD40. Recently I’ve started putting on a coat of Johnson’s Paste Wax occasionallly. (It helps that I’m in a low humidity area.)
woodbutcherbynight
#4 posted 11-10-2017 04:48 AM
- Rick_M
I am going to try this on my benchtop drill press.
View Hackmeister's profile
Hackmeister
2 posts in 410 days
#5 posted 11-10-2017 05:58 AM
It will depend a lot on where you live, how much humidity and temp variation you have, and how much you climate control your shop. I’m in MN, but I heat the shop in the winter to about 60, and AC it in the summer to keep the humidity down (the shop is well insulated and one of the dogs lives in there), and I never have rust issues on any of my machines or tools. I have even left unfinished white oak on the table saw top for a month without a mark.
That said, in unheated and un-airconditioned shops I have worked in here, some have had problems with rust and corrosion. The worst were ones with wide swings in temperature throughout the day, where the tools get condensation on them because they stay colder than the air as it heats up early in the day. In those, we did need to keep wax or oil or something on the unpainted surfaces to protect them.
View Sarit's profile
Sarit
549 posts in 3133 days
#6 posted 11-10-2017 08:20 AM
I say don’t worry about it. Once you remove the old rust and wax the cast iron table real good, it will take some time for it to rust again even when covered with wood. I sold my last benchtop drill press with the wooden table and the buyer didn’t even consider to check the cast iron table that was underneath it. I don’t think you will get pitting with shop use and a dehumidifier. The most you should see is some light surface rust that is easy to remove whenever you get around to it, if ever.
View Lazyman's profile
Lazyman
1934 posts in 1381 days
#7 posted 11-10-2017 12:18 PM
I’ve seen the water based poly idea before but can’t bring myself to try it (don’t want to have to remove it if I don’t like it).
Just apply some paste wax periodically on any unprotected steel surfaces and you’ll be fine.
View HorizontalMike's profile
HorizontalMike
7754 posts in 2908 days
#8 posted 11-10-2017 12:23 PM
JPW applied with #0000 steel wool. PLUS, I now have a mini-split AC system in the shop that can be set to dehumidify that works great.
ribaldplaner
4 posts in 201 days
#9 posted 11-10-2017 05:21 PM
Wow – thanks for the replies.
Sounds like paste wax on the exposed iron will be enough.
Oil based poly on the base of the wooden table (multiple layers, allowed to cure) will also help if I decide to go that route.
Thanks all!!
Tim
Woodknack
#10 posted 11-10-2017 05:42 PM
I ve seen the water based poly idea before but can t bring myself to try it (don t want to have to remove it if I don t like it).
- Lazyman
There is literally no difference with it on there (other than rust prevention), you wouldn’t know unless I told you. I put on one thin coat. One benefit is it gets down into any imperfections, pores, whatever, and provides permanent protection.
View bc4393's profile
bc4393
65 posts in 1136 days
#11 posted 11-10-2017 08:06 PM
Here’s a hell of a test.
http://www.dayattherange.com/?page_id=3667
On that note I use CRC3-36 due to some recommendation from fine woodworking or something somewhere and it works well in my Houston (it’s really humid here in case you were unaware) garage. Every couple of months or after some heavy use I reapply. Plus it’s fairly more readily available than the WD specialist in the test above.
View MinnesotaSteve's profile
MinnesotaSteve
49 posts in 885 days
#12 posted 11-10-2017 08:38 PM
Spray shellac… Just a light coat from a spray can.
http://lumberjocks.com/topics/51551
