grizzly table saw 1023 right tilt
Forum topic by Chad_B posted 11-09-2017 11:41 PM 762 views 0 times favorited 10 replies Add to Favorites Watch
View Chad_B's profile
Chad_B
45 posts in 635 days
11-09-2017 11:41 PM
I recently aquired a grizzly table saw 1023 right tilt cabinet saw, for free.
I am having an issue with the T-square fence that originally came with the saw. When I lock the front down, the back of the fence is not secure, I moves about 1/8-1/4” when pressure is applied.
Does anyone know how to remedy this issue or am I looking at buy a new fence/rail system.
On the back of the fence there is a metal plate with two bolts on the top and one the bottom that holds a bearing. If anyone is familiar with this set up.
Suggestions for a replacement would be great if I am wasting my time with the current fence.
One more question, different subject, the saw had a magnetic switch on it that is no longer working. I wired a plug directly to the motor to bypass the switch, in order to confirm the switch was the issue. Are these switches repairable or is there another option I can use for a switch (like a light switch for example) I don’t want to invest too much money in this saw yet. So Id rather fix what I have instead of replacing.
This is my first table saw that isn’t a job site saw, so I am a little out of my league.
Thanks for any help
Chad
10 replies so far
View firefighterontheside's profile (online now)
19588 posts in 2091 days
#1 posted 11-09-2017 11:44 PM
I’m not familiar with the fence. As far as the switch goes, I’d buy a new magnetic switch from grizzly for safety.
MrUnix
7103 posts in 2433 days
#2 posted 11-10-2017 12:18 AM
Without seeing what you are talking about, all we can do is guess. Same deal with the starter… If it’s an IEC type, then just consider it disposable. If it’s a NEMA starter, you can replace individual parts. Oh, don’t use a light switch – they are not designed for inductive loads and the contacts will toast fairly quickly… that and the fact that they do not provide any overload protection like the starter does.
View Loren's profile
10477 posts in 3882 days
#3 posted 11-10-2017 12:34 AM
Magnetic switches can be serviced but it may
not be worth the trouble. You can open it up
and look at the contacts. They are flat conductive
discs that come together and complete the circuit.
The surface condition of these contact discs affects
the operability of the switch. Sometimes the discs
can be reconditioned with fine sandpaper. Sometimes
they are thoroughly burnt and unsalvageable.
A t-square fence should not deflect like that. It’s
probably missing a plastic pad in the locking part
or something like that.
runswithscissors
2917 posts in 2260 days
#4 posted 11-10-2017 06:21 AM
The other reason for a magnetic switch is that in case of a power stoppage, the magnet (or cutting off of the magnet) opens the switch, so that when the power comes back on, it won’t start up unintentionally.
Chad_B
#5 posted 11-11-2017 12:44 AM
Chad_B
#6 posted 11-11-2017 03:46 PM
Anyone have any suggestions on the fence
View sras's profile
sras
4965 posts in 3364 days
#7 posted 11-11-2017 05:08 PM
I have had that saw for 10 years. Yes, if you push on the fence at the back it will move. Typically there is no force being applied to the back of the fence while cutting. I have never had an issue with straight cuts. If the fence is parallel to the blade you should be just fine.
117416 posts in 3812 days
#8 posted 11-11-2017 05:27 PM
I agree with Loren
about both issues I might add the obvius make sure the saw is unpluged.
Like Loren said it could be missing a plastic guid that goes on the inside of lock down area of the fence or the adjustment screws are loose or missing.
ajustment screws
plastic pads/guides
MrUnix
#9 posted 11-11-2017 07:47 PM
That is an IEC type starter… so unless it’s something simple, fixing it will not be easy as the parts are really hard to find individually. If you are not good at troubleshooting electrics, then you will most likely need to replace it. Can’t tell the model number, but Grizzly sells them on their web site. Here is one such example:
(Can be found here)
Chad_B
#10 posted 11-13-2017 03:16 PM
Thank you for the help everyone, Ill update with the fix as soon as I get everything squared away.
