Are my Unisaw extension wings attached correctly?
Forum topic by stevet47 posted 11-09-2017 10:35 PM 1479 views 0 times favorited 9 replies Add to Favorites Watch
View stevet47's profile
stevet47
20 posts in 1497 days
11-09-2017 10:35 PM
I picked up a used unisaw and have been going through it, cleaning/adjusting everything, and I noticed the cast iron extension wings do not bolt onto the fence rail. I would think they are supposed to be bolted in for added support, but the holes don’t line up.
As far as I know, this is the original fence that came with the saw, but perhaps it was installed incorrectly.
Should I drill the fence rail where the existing holes in the extension table are and add bolts, are the fence rails installed wrong (it doesn’t look like they would like up with any of the other holes either) or is it fine the way it is?
9 replies so far
MrUnix
7106 posts in 2436 days
#1 posted 11-09-2017 10:48 PM
There are only two ways to attach those table extensions… with the shiny side up, or the shiny side down… so yours looks like you got it right :)
The Biesemeyer fence manual specifically states that the holes are NOT supposed to line up. If you want to attach the fence to the wings, you will need to do some drilling.
stevet47
#2 posted 11-10-2017 03:36 PM
Well ok then. I suppose if Biesemeyer says they aren’t supposed to line up, I won’t worry about it!
View Ripper70's profile
Ripper70
1194 posts in 1145 days
#3 posted 11-10-2017 04:07 PM
Well ok then. I suppose if Biesemeyer says they aren t supposed to line up, I won t worry about it!
- stevet47
If it were me, I would definitely drill the extra holes. I’d put two in each wing.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
runswithscissors
2924 posts in 2262 days
#4 posted 11-11-2017 12:04 AM
Cast iron is not difficult to drill and tap.
View jonah's profile
jonah
1972 posts in 3535 days
#5 posted 11-11-2017 01:50 AM
You don’t even need to tap it. You can just drill through holes and bolt it on with nuts on the back side.
runswithscissors
#6 posted 11-11-2017 05:10 AM
What Jonah says is correct. But it depends on where the hole comes out on the other side. Sometimes there will be webbing or some other uneven surface there, in which case tapping is a good way.
jonah
#7 posted 11-11-2017 12:04 PM
Good point. In any case, you’re right that most any reasonably sharp twist drill bit will go through cast iron quite easily, and tapping isn’t hard either.
stevet47
#8 posted 11-11-2017 03:18 PM
Thanks guys, but I suppose the question is, SHOULD they be bolted, not CAN they be bolted. From MrUnix’s post, it appears the manufacturers did not intend for them to be bolted, is there a reason for this, or should I just go for it?
Are everyone elses saws bolted?
jonah
#9 posted 11-11-2017 04:59 PM
I bolted my rails to the extension wings. The wings attach to the table with very beefy 5/8” bolts, IIRC, but I figured the more support there the better. IMO, there’s no downside to attaching them to the rails so long as you make sure they’re flush and level with the main table.
