Miter sled for cutting bowl segments
Forum topic by 8iowa posted 265 days ago 430 views 5 times favorited 4 replies Add to Favorites
View 8iowa's profile
8iowa
187 posts in 289 days
265 days ago
I made this miter sled for my son-in-law, who is expanding his turning interests into segmented bowls. The basic plan for this sled came from “Segmented Turning” by Bill Kandler. This book is available from Bill at www.segmentedturning.com . The width of the miter sled to the left of the blade, and the depth, can be changed to accomodate your particular saw’s table. However, all the critical cutting action takes place in the upper right hand corner. Here, you should keep the dimensions as per the plan. I made the sled out of 3/4” Baltic Birch, although other flat and dimensionally stable materials can also be used.
With the blade perfectly alligned with the miter slots, and a sharp crosscut blade, the angle of the fence can be tweaked to the last hair’s breath of an angle. I made four fences; for six, eight, ten, and twelve sided segments. Note my “air tight” assembled segments.
<insert>miter sled view #1mage here>
A standard type clamp is used to hold the stop block in place on the far right side of the fence. It of course can be moved to create segments of various lengths. Note that I have added a toggle clamp on the fence, just to the right of the blade, as some segments are cut in very short lengths.
<insert>miter sled #3age here>
According to Kandler, segments cut on this sled seldom require additional sanding.
2057 posts in 550 days
265 days ago
Very clean job 8:
I made a similar one a while back to do segments and made this bowl it.
Regards
6517 posts in 379 days
265 days ago
Now that is something I haven’t tried. Thanks for sharing.
View cajunpen's profile
cajunpen
5345 posts in 594 days
265 days ago
That is a handing looking sled. Thanks for the info.
View Chris 's profile
Chris
1259 posts in 519 days
260 days ago
Great sled. I’ve been interested in segmented turning for a while know. This would really come in handy.
-- Chris
Bookmark And Share This Page
