Setting up wood glue in cold garage
Forum topic by JohnnyBoy1981 posted 11-09-2017 07:39 PM 2721 views 0 times favorited 9 replies Add to Favorites Watch
View JohnnyBoy1981's profile
JohnnyBoy1981
235 posts in 640 days
11-09-2017 07:39 PM
Topic tags/keywords: woodglue cold temperatures uninsulated garage
My detached is detached and uninsulated, so here in Nebraska it gets chilly. I’ve read a few articles on heating garages for woodworking, but installing a legit permenant heater isn’t in the budget. I use a portable BigBuddy propane heater.
My question is a bit more specific: my big holdup is using woodglue in colder temps. If I kept the space heater pointed at the glue and the glue up area, could the glue be kept warm enough to cure? The pine I’m using has been in the garage and is therefore cold. Would that negatively affect the adehesion of the glue to the wood?
9 replies so far
View Loren's profile
10477 posts in 3850 days
#1 posted 11-09-2017 07:54 PM
Never tried one, but this might be worth a look.
View higtron's profile (online now)
higtron
245 posts in 2880 days
#2 posted 11-09-2017 07:55 PM
Try an electric blanket, wrap or cover glued item in blanket for a few hours to overnight. In answer to your question I think if the glue doesn’t freeze it would probably set at some point what the strength of that union would be compared to a glue up in 60 deg. weather would be, I don’t know I’m sure someone has done a test of that very thing(Matthias Wandel!!!).
-- A friend will help you move, a good friend will help you move a body
View Rich's profile
Rich
3883 posts in 792 days
#3 posted 11-09-2017 09:07 PM
For starters, PVA glue gets ruined if it freezes and thaws more than a couple of times. it’s pretty easy to just store the glue in your house and grab a bottle when you head to the shop.
Regarding the temperature of the wood, do some samples. Take two boards and glue them together overlapping by an inch or two. You want long grain to long grain. Let it cure at least 24 hours and then clamp it in a vise and knock one piece off with a hammer. If the wood tears, you’re good, but if it breaks cleanly along the glue line you have a problem.
View corelz125's profile
corelz125
568 posts in 1179 days
#4 posted 11-09-2017 09:33 PM
I know on titebond it says in bold letters keep from freezing so i keep it inside and glue things up inside during the cold months.
View LesB's profile
LesB
1865 posts in 3646 days
#5 posted 11-09-2017 09:47 PM
Titebond says not to use at temperatures above 50 degrees. Pretty simple.
Here is a quote from another forum on this subject:
“I received an excellent response in just 30 minutes. I thought I would share this information, as well as give a big thumbs-up to the customer service.
Titebond III will not chemically perform at or below its stated Chalk temperature of 47° F. If you reduce the temperature of the wood, glue or room below the chalking temperature, the glue does not coalesce (form a continuous film) on drying. This is evidenced by a dried film which is whiter than normal and looks “chalky.” Where the bond is formed at all, the resultant strength of a chalked glue joint is lower than normal and will always remain weak and often times will fail.
In regards to timeframe, the temperature really needs to be maintained for a minimum of 24 hours after glue up. At temperatures closer to the 47° F, you may want to wait 36 hours to be sure the glue has dried completely.”
-- Les B, Oregon
View alittleoff's profile
alittleoff
541 posts in 1479 days
#6 posted 11-09-2017 10:01 PM
I’ve used tite bond 2 at or about 50 degrees and may have gotten down over night to 30 degrees I’m not sure, but the joints held and still are. I was glueing 2×4 pine lumber together for a table top and had no trouble at all. I was doing this for myself so it really didn’t matter. If wanted to make sure and was doing it for someone else I’d do like was said before I’d do a test. I personally think if it dont freeze it will hold. IMO
Gerald
View DS's profile
DS
3033 posts in 2623 days
#7 posted 11-09-2017 10:08 PM
There is a Titebond employee (chemist) who has commented on here in the past.
LJ GlueNerd
See his post here; http://lumberjocks.com/Midway/blog/112153
There is a toll free number on their website to receive qualified answers to questions like this.
They seemed more than eager to help out.
JohnnyBoy1981
#8 posted 11-10-2017 01:41 AM
The glue bottles stay in the house in the winter; they don’t freeze.
However, since posting this question, I think I’ve figured out another way to do what I need to do.
Thanks.
JohnnyBoy1981
#9 posted 11-10-2017 01:56 AM
- LesB
Excellent! This is exactly what I was wondering! Thanks!
