Band Saw problem Rikon 10-324
Forum topic by nutmegger13 posted 11-08-2017 10:59 PM 1009 views 0 times favorited 3 replies Add to Favorites Watch
View nutmegger13's profile
nutmegger13
16 posts in 386 days
11-08-2017 10:59 PM
Topic tags/keywords: bandsaw bandsaw blade rikon bandsaw question
Hello I have a Rikon bandsaw model 10-324. I bought the updated guide kit which I like. Recently I bought a 3/16 4 TPI blade from Timberwolf. I want to make some bandsaw boxes. I am having a very difficult time getting the blade to stay on the wheels without popping off. I am adjusting the top wheel to try to keep it centered and also adjusting the tension. The blade does not stay centered on the top wheel without a whole lot of fiddling. Other blades I have, 1/4 inch and 1/2 inch are no problem. Any ideas?
-- nutmegger13, Connecticut
3 replies so far
View WhyMe's profile
WhyMe
1049 posts in 1682 days
#1 posted 11-09-2017 12:03 AM
If you install the blade centered and first set the tension correctly you should not have to fiddle with the tension to adjust the blade position. All you should need to do is adjust the upper wheel tracking. At least that’s how it works for me with a 3/16” blade.
nutmegger13
#2 posted 11-09-2017 09:27 PM
Thanks for the advise. Maybe I am not tensioning the blade correctly. I noticed that the preset factory settings are off from what they should be. Am I correct in tensioning it so it can only be deflected 1/4 inch when pushed midway between the upper wheel and table? Thanks you again.
View toolie's profile
toolie
2143 posts in 2750 days
#3 posted 11-09-2017 11:00 PM
dump the t-wplf. there’s a reason they are often sold 4 for the price of three, and consistently quality welds are not the reasons for the discounts. try Iturra Designs. Lou knows how to weld a band saw blade. get at least one blade form Lou so you can diagnose your issues, then experiment w lesser blades, like Timberwolf.
