Bandsaw Box Blade Size?
Forum topic by rustynails posted 11-07-2017 11:29 PM 894 views 0 times favorited 3 replies Add to Favorites Watch
View rustynails's profile
rustynails
751 posts in 2551 days
11-07-2017 11:29 PM
What size blades are the best for cutting bandsaw boxes? Is a 3/16 4TPI the
best all around size to use? I have never made a box before and plan on
trying my hand at it and have read a few people saying they use this size. What
is everyone using or recommending for a all around blade size.
Thanks Richard
3 replies so far
View MrUnix's profile
MrUnix
6757 posts in 2221 days
#1 posted 11-07-2017 11:54 PM
Depends on your design and how tight you want your corners. Unless you are using something like the Carter Stabilizer on your machine, here is the generic blade size minimum radius chart:
Generally, smaller is better on boxes since you sort of want some rather tight curves. I’ve used 1/4” blades before (smallest I have), and it worked but was a bit of a challenge. 3/16 would have been a better choice (and 1/8” would have been ideal).
View BandsawJeff's profile
BandsawJeff
52 posts in 222 days
#2 posted 11-08-2017 03:26 AM
You may want to considering something with a higher tooth count also….maybe a 6tpi. It will make for a smoother cut therefor less sanding.
rustynails
#3 posted 11-08-2017 10:02 PM
Thanks guys for your recommendations and tips.
