Jewelry Door offset
Forum topic by Bohaiboy posted 11-07-2017 04:17 PM 456 views 0 times favorited 8 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 2033 days
11-07-2017 04:17 PM
I am building the wife a jewelry armoire that will have swinging doors on the side to contain necklaces. The door will be located on top of the base. How much offset should I allow for to prevent the door from sagging and dragging? I am thinking 1/8” but maybe it should be more or less. Picture shows left door
-- Tim, Houston, TX area
8 replies so far
View Ripper70's profile
Ripper70
1196 posts in 1148 days
#1 posted 11-07-2017 04:23 PM
How large is this piece? Dimensions may help to determine overall scale and what’s appropriate in your instance.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
Bohaiboy
#2 posted 11-07-2017 04:44 PM
The door is approximately 20” tall and 14” wide and 2” thick. Will be 3/4 mesquite for the rails and stiles and 1/2” mesquite for the panel. I need the 1/2” thickness to be able to mount the knobs for hanging the necklaces.
Bohaiboy
#3 posted 11-07-2017 04:48 PM
The overall width of the total project is approx 25” and overall height approx 54”
View Loren's profile
10477 posts in 3887 days
#4 posted 11-07-2017 05:15 PM
1/8” will probably be fine, maybe a little
excessive if you want to work to fine
tolerances. If you’re really concerned you
might want to make mock-ups out of
plywood to figure out how to go about
mounting the hinges.
Bohaiboy
#5 posted 11-07-2017 05:39 PM
Loren, What would you suggest for the drawer spacing?
#6 posted 11-07-2017 05:43 PM
3/32” looks good and is not too difficult
to achieve. It also allows a little room for
wood movement.
View LesB's profile
LesB
1922 posts in 3682 days
#7 posted 11-07-2017 05:58 PM
I agree with Loren. I have built large wall clocks and used 1/16” clearance for the doors with no problem.
Have you considered using a piano type hinge? That will make the door’s mounting very stable. The alternative is a set of good “tight” (no play) hinges.
-- Les B, Oregon
View Andybb's profile
Andybb
1614 posts in 843 days
#8 posted 11-08-2017 06:13 AM
20” tall might be tall enough that it won’t be necessary but something else you might want to consider….I’m working on a similar project and am adding an enclosure at the bottom of the door like the below design just in case a necklace hangs longer than the height of the door.
-- Andy - Seattle USA
