Countertop Joining Fasteners
Forum topic by Gilley23 posted 11-07-2017 01:51 PM 587 views 0 times favorited 7 replies Add to Favorites Watch
View Gilley23's profile
Gilley23
489 posts in 500 days
11-07-2017 01:51 PM
There are lots of choices out there, but I’m not sure what is better than others and what is worth the money and what isn’t. This is for the underneath joining of butcher block counters, something to draw them in tight to each other.
Any suggestions on preferred products? I’ve been looking at these, but at $40 for two packs I’m hesitant to pull the trigger: https://www.amazon.com/Zipbolt-UT-10-900-Drawbolt-Pack/dp/B0716SK9FN/ref=sr_1_7?ie=UTF8&qid=1510009636&sr=8-7&keywords=Countertop+bolts
7 replies so far
View ChefHDAN's profile
ChefHDAN
1122 posts in 2967 days
#1 posted 11-07-2017 02:05 PM
I used the woodriver ones bit easier to get the wrench on
View Lazyman's profile
Lazyman
2387 posts in 1505 days
#2 posted 11-07-2017 05:47 PM
A problem with the one you linked at Amazon is that you have to be able to cut a flat bottomed recess for the flat washer. The Woodriver ones can be done with a forstner bit which will be much easier to do IMO… not to mention a lot cheaper too. Search for “countertop joint connector” on Amazon to see a few other options there.
View AlaskaGuy's profile
AlaskaGuy
4361 posts in 2427 days
#3 posted 11-07-2017 05:49 PM
- Lazyman
Zipbolt UT 10.500 – 80mmx35mm This one has no flat bottom.
http://zipbolt.com.au/product-items/zipbolt-ut-10-500-81mmx35mm/
https://www.amazon.com/product-reviews/B0725NYDTN/ref=pd_lpo_vtph_60_tr_cr_2?ie=UTF8&refRID=RQG8N61AS3VJJ982H9SV
AlaskaGuy
#4 posted 11-07-2017 06:10 PM
- ChefHDAN
The zip bolts require no wench at all.
Gilley23
#5 posted 11-07-2017 09:04 PM
Ohhhh good thinking about the flat bottom, didn’t think about that.
View dhazelton's profile
dhazelton
2789 posts in 2414 days
#6 posted 11-07-2017 09:18 PM
Pocket screws?
ChefHDAN
#7 posted 11-10-2017 01:20 PM
- AlaskaGuy
Thanks AKGuy, those look VERY SLICK, and perhaps worth spending 5x more since I’m not producing a great deal of tops!
