Ripping on a table saw
Forum topic by DIY1 posted 11-07-2017 11:21 AM 834 views 0 times favorited 11 replies Add to Favorites Watch
View DIY1's profile
DIY1
6 posts in 202 days
11-07-2017 11:21 AM
I have noticed while ripping a large 2X on my table saw the board ends seem to be tapered. Then have to run the boards on a jointer to get them true. Is there a better way to cut them on a table saw?
11 replies so far
View jonah's profile
jonah
1702 posts in 3298 days
#1 posted 11-07-2017 11:24 AM
Sounds like your fence is not aligned parallel with the blade.
View cabmaker's profile
cabmaker
1731 posts in 2809 days
#2 posted 11-07-2017 11:30 AM
Cant say if there is a better way…...what way are you doing it now ?
What are you considering to be a large 2X ?
Have you considerd jointing one edge first, then ripping ?
View richardchaos's profile
richardchaos
583 posts in 379 days
#3 posted 11-07-2017 11:36 AM
Are you using a RIDGID 4512 TS?
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
cabmaker
#4 posted 11-07-2017 11:51 AM
- richardchaos
hahaha!!
View JBrow's profile
JBrow
1354 posts in 920 days
#5 posted 11-07-2017 12:28 PM
DIY1,
Jonah may well be correct if the taper runs the full of the lumber. But since it only happens on larger 2x stock (I assume longer) and the taper can be removed at the jointer, the taper sounds as if it only occurs on the last 1’ – 2’ of the longer board. If the taper only occurs on the last length of the longer boards, then it could be that as there is less board to hold as the cut nears completion and the board is rotating into the blade.
Some ideas to control the longer board are to ensure that there is outfeed support. The outfeed support would allow for greater attention to keeping the board against the fence throughout the cut. If the outfeed support is a roller stand, then intentionally angling (slightly) the roller so that roller tends to rotate the infeed end of the board toward the fence could possible help. Of course, focusing attention on the edge and the board and the fence, working to keep these surfaces in firm contact throughout the cut is critical. Since this requires diverting attention away from hand placement as it relates to the blade, using a blade guard during these cuts could add a greater margin of safety.
Using a feather board set on the infeed side of the blade’s infeed edge could also be effective in keeping the stock in contact with fence throughout the cut.
View pontic's profile
pontic
583 posts in 608 days
#6 posted 11-07-2017 01:20 PM
If you have an outfeed roller support then cant the rollers into the fence slightly then the board will always roll into the fence giving less chance of tapering at the end.
-- Illigitimii non carburundum sum
View rwe2156's profile
rwe2156
2926 posts in 1480 days
#7 posted 11-07-2017 04:01 PM
I doubt its the saw but its always worth it to check alignment.
Few things to check regarding your technique:
1) the edge against the fence has to be jointed straight.
2) the edge against the fence must be kept against the fence all the way through the cut
3) use a riving knife or splitter
4) be sure you are using the correct blade and that is it sharp (lots of cutting errors are the result of dull blades and/or underpowered saws)
5) be sure to support the outfeed part of a long board.
You can employ aids such as a long auxilary fence and feather boards .
View Ripper70's profile
Ripper70
995 posts in 908 days
#8 posted 11-07-2017 04:16 PM
Try using one of these to help accomplish suggestion #2 above.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View pintodeluxe's profile
pintodeluxe
5661 posts in 2813 days
#9 posted 11-07-2017 04:24 PM
2X as in framing lumber 2×4? Usually framing lumber has no straight edge. The good studs are bowed “only” 1/4.” It is a world of difference working with hardwood lumber that has been freshly jointed.
I’m not saying there isn’t a setup issue with the saw, but if the lumber is bowed we haven’t got a chance for a straight and even cut.
jonah
#10 posted 11-07-2017 05:15 PM
Even if the board were cupped or otherwise warped, it wouldn’t necessarily come out tapered. Tapered, to me, is 95% of the time due to the fence being misaligned.
pintodeluxe
#11 posted 11-07-2017 05:43 PM
Or the board moving away from the fence because it’s not straight lumber.
