Finishing dovetails
Forum topic by umbach posted 02-17-2011 08:45 AM 1399 views 0 times favorited 9 replies Add to Favorites Watch
View umbach's profile
umbach
41 posts in 2897 days
02-17-2011 08:45 AM
Ok. I’m finishing a cherry bookcase and staining it a bit darker than natural. How do I stain the dovetails on the side of the drawer wo getting any stain on to the lighter colored poplar drawer sides?
9 replies so far
View Don's profile
Don
517 posts in 3314 days
#1 posted 02-17-2011 10:47 AM
Use masking tape and be carefull not to apply too much stain or it can bleed under under the tape.
-- Don - I wood work if I could. Redmond WA.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4369 days
#2 posted 02-17-2011 01:53 PM
Pre-stain before assembly, seal with shellac then assemble and finish.
-- 温故知新
umbach
#3 posted 02-17-2011 03:33 PM
Thanks guys. It’s a bit late to pre stain but I shall remember that next time! Masking tape it is.
View NBeener's profile
NBeener
4816 posts in 3415 days
#4 posted 02-17-2011 04:38 PM
Next time ….
You MAY want to try Frog Tape
The paint doesn’t bleed through. Gives you really good control in these end-grain situations :-)
-- -- Neil
umbach
#5 posted 02-17-2011 05:01 PM
Thane Beener. I have some of that and was planning on using it.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3400 days
#6 posted 02-17-2011 05:16 PM
I don’t trust tape in those situations. I like to use a fine artist’s brush to apply the stain for more control.
But yeah, pre-assembly is best in that situation. Just be sure to keep the glue surfaces clean.
-- jay, www.allaboutastro.com
hObOmOnk
#7 posted 02-17-2011 05:21 PM
When I did restoration work, I would use artists brushes to apply stains and toners in difficult places.
I even used a magnifier attached to my glasses to help see what I was doing.
Masking tapes won’t work because of bleed through the grain.
Hope this helps…
-- 温故知新
View Don's profile
Don
#8 posted 02-18-2011 04:52 AM
I don’t think the pre-stain method would work very well. You’d have to cut the dovetails to fit perfectly flush which is difficult to do. If they are even a tiny bit proud you’ll be sanding the stain off when you sand them flush.
View pintodeluxe's profile
pintodeluxe
5819 posts in 3054 days
#9 posted 01-18-2013 10:00 PM
Old post I know, but interesting topic.
Don, I have had good luck cutting the dovetails and dry assembling them. This gives me a chance to sand the joint flush. Then the front can be stained separately. Assembly is easy, and you already know everthing fits perfectly.
