Breadboard ends with even number of panels
« back to Joinery forum
Forum topic by maxyedor posted 11-06-2017 07:08 PM 557 views 0 times favorited 4 replies Add to Favorites Watch
View maxyedor's profile
maxyedor
24 posts in 563 days
11-06-2017 07:08 PM
Not sure if I’m wording this correctly, but I’m building a table-top that needs to be 40” wide, the lumber I got for it 5.25” wide, so jointed it can be 5” or smaller. If I do 8 5” wide boards it’s perfect, but that results in a seam right dead in the middle. Normally I’d pin the center board to the breadboard end, and then let the rest float for expansion/contraction, but with none in the middle, I’m not sure which one to pin. Any suggestions?
View Carloz's profile
Carloz
1147 posts in 830 days
#1 posted 11-06-2017 07:10 PM
Does it matter ? take any board, or pin both closer to the center.
maxyedor
#2 posted 11-06-2017 08:08 PM
Not sure if it matters, I guess I could pin the one next to the centerline and it’s only going to be 2.5” off center anyway, so it shouldn’t matter. I’ve just never seen an even number of boards in a breadboard style table top, started to get worried if there was a reason for that.
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#3 posted 11-06-2017 08:40 PM
I don’t see why it matters. The glue line shouldn’t be an issue its stronger than the wood.
View splintergroup's profile
splintergroup
2511 posts in 1461 days
#4 posted 11-07-2017 02:42 PM
Typically you glue the center few inches since expansion shouldn’t cause issues over that narrow span.
Glue, clamp, and pin (in the center), then pin the outer extents. Be sure to elongate your pin holes for the outer (unglued) pins.
