Leather handles on a toolbox
Forum topic by Bigb1006 posted 11-06-2017 02:21 PM 639 views 0 times favorited 12 replies Add to Favorites Watch
View Bigb1006's profile
Bigb1006
5 posts in 286 days
11-06-2017 02:21 PM
Hi I’m designing a toolbox and I want it to have leather handles. I was planning on attaching them using upholstery tacks. After thinking about it I’m not sure if they will be able to hold the weight. I was wondering if anyone had suggestions on how to attach leather handles so they would be able to support the weight.
12 replies so far
View mpounders's profile
mpounders
881 posts in 2979 days
#1 posted 11-06-2017 02:42 PM
I used to refinish a lot of antique trunks and the handles were attached used nails that were “clinched” over on the inside. The nails were flat cut nails and i would try to select ones that were long enough to penetrate the leather and the wood with may be a 1/4 inch to spare on the inside. I would hold a small iron against the inside and attempt to bend the nail back as I hammered from the outside. Sometimes it was necessary to start the inside bend with pliers. I used three nails on each side of the handle. The leather will rot before the nails pull loose!
-- Mike P., Arkansas, http://mikepounders.weebly.com
View Loren's profile
10477 posts in 3732 days
#2 posted 11-06-2017 05:15 PM
Glue holds leather pretty well. Combined with
tacks it may hold adequately. Clinching is not
a bad idea. Screws with washers may not
be pretty but the washer will be big enough
to prevent the screw head tearing through the
leather.
View pintodeluxe's profile
pintodeluxe
5736 posts in 2897 days
#3 posted 11-06-2017 05:30 PM
I would do one of two things… make a wooden handle and wrap it with leather, or use metal grommets to secure the leather strap. Then use a fastener that allows the grommet to swivel a little.
Running a couple rows of topstitching makes a great looking strap handle. You can use contact cement on leather, and fold it in half lengthwise to make a sturdy strap.
View CharlesNeil's profile
CharlesNeil
2426 posts in 3954 days
#4 posted 11-06-2017 05:46 PM
Horton Brasses has leather handles and attachment hardware.. pretty nice IMO
https://www.horton-brasses.com/searchadvanced.asp?searchfor=leather
Bigb1006
5 posts in 286 days
#5 posted 11-06-2017 10:23 PM
Thanks for all the suggestions, I was thinking about using glue and the tacks but I figured I would ask.
View Lazyman's profile
Lazyman
2287 posts in 1471 days
#6 posted 11-07-2017 03:58 AM
How heavy do you expect it to be? If it’s very heavy, I would think the glue would eventually fail.
I think you need to buy or make something along these lines.:
http://www.leevalley.com/us/wood/page.aspx?p=40643&cat=3,41427,41377&ap=1
View Woodknack's profile
Woodknack
12234 posts in 2464 days
#7 posted 11-07-2017 04:08 AM
Bigb1006
5 posts in 286 days
#8 posted 11-07-2017 04:11 AM
Are there decorative rivets that could go through about an inch of material.
View MikeB_UK's profile
MikeB_UK
141 posts in 1118 days
#9 posted 11-07-2017 09:21 AM
- Bigb1006
Saw bolts would work if you can’t find big enough rivets.
-- If I say I'll fix something around the house I will, there is no use nagging about it every 6 months.
View Bluenote38's profile
Bluenote38
299 posts in 472 days
#10 posted 11-07-2017 12:57 PM
Check out Jimmy DiResta’s Oak & Leather Toolbox.
-- Bill - Rochester MI
Smitty_Cabinetshop
15443 posts in 2702 days
#11 posted 11-07-2017 01:29 PM
I’d suggest a Google image search for “steamer trunk handles” as a source for suitable approaches. Glue and tacks IMO ain’t gonna do it for you.
View Jim Finn's profile
Jim Finn
2663 posts in 3006 days
#12 posted 11-07-2017 01:50 PM
Mabe “Chicago screws” or bolts would work for this.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
