When 45º isn't...
Forum topic by Kelly posted 11-06-2017 01:22 PM 715 views 0 times favorited 14 replies Add to Favorites Watch
View Kelly's profile
Kelly
69 posts in 1807 days
11-06-2017 01:22 PM
I’ve been trying to cut some boxes and something is a little off. I cut some 45º miters but they appear to be cutting at less than 45º even though both my square and digital gauge show the blade is at 45º. The drawing shows what I’m ending up with.
I ran all the lumber through the jointer (I checked that for square too) so as to start with a square edge, but somehow am losing a degree or two when I’m cutting the miters.
Does anyone have any ideas what might be going on?
Thanks,
Kelly!
I drew this using 44º miters, to show what is happening. I’m not sure what the exact angle is but the effect is the same, with each corner being greater than 90º.
14 replies so far
View mahdee's profile
mahdee
3883 posts in 1766 days
#1 posted 11-06-2017 01:28 PM
Many times the wood has a tendency to move as it is being cut with the blade tilted. clamp the wood to the miter before running it through.
-- earthartandfoods.com
View Lazyman's profile
Lazyman
1964 posts in 1386 days
#2 posted 11-06-2017 01:33 PM
Is your insert flat? Make sure that it doesn’t have a bow in it and is adjusted perfectly level with the table. You could try making a quick and dirty sled and see if that helps.
View dhazelton's profile
dhazelton
2767 posts in 2295 days
#3 posted 11-06-2017 02:05 PM
If you crosscut all your pieces on a sled then you can cut the mating joints on the opposite side of the blade so no matter what you have a 90 degree joint.
View Rich's profile
Rich
2824 posts in 588 days
#4 posted 11-06-2017 02:47 PM
- dhazelton
Bingo. +1
View jonah's profile
jonah
1702 posts in 3297 days
#5 posted 11-06-2017 03:08 PM
+1 as well. You can also do the same thing with a miter gauge if you can use it on either side of the blade.
So long as you end up with complementary angles, it doesn’t really matter if they’re 45 degrees or not.
View rwe2156's profile
rwe2156
2925 posts in 1479 days
#6 posted 11-06-2017 03:17 PM
Check that ZCI for flush to top.
The wood needs to be dead flat. If this is not the case, using a sled won’t help.
If you’re just running the wood through there could be another cause. A left tilt blade with fence on right will have tendency to lift wood. Counter this with a push block to keep the wood pushed down against the table.
View splintergroup's profile
splintergroup
2014 posts in 1221 days
#7 posted 11-06-2017 03:27 PM
The complementary angle approach is a winner, but any method requires consistency. Aside from the usual issues with square stock, make sure (clamp) that your stock is secure to your miter gauge and doesn’t move during the cut.
When using a stop block to cut the opposite miter, have the stop block register to the stock some where in the center of the miter, not the tip (think of an “L” shaped stop).
Cut some scraps to the same size and use these to tweak your blade angle before you begin cutting your box pieces.
View waho6o9's profile
waho6o9
8191 posts in 2575 days
#8 posted 11-06-2017 03:44 PM
+ 1 for splintergroup. I like using Bessey hold down clamps.
View MrRon's profile
MrRon
4769 posts in 3242 days
#9 posted 11-06-2017 06:11 PM
Any “Wixey” type gauge or 45° triangle is never perfect. Just being off by a few minutes, can make a difference. Blade runout, fences, miter gauges can all have a minor inaccuracy and it can add up to a less than perfect miter cut. A 45° miter cut on 3/4” wood that is off by as little as 1/10 of a degree or 6 minutes, will leave a gap at the miter of almost .004”.
10394 posts in 3646 days
#10 posted 11-06-2017 06:16 PM
The family of jigs exemplified by this example can help dial in miter cuts.
If I were making miters often I would want
a disc sander. They’re good for fudging
miters. A donkey’s ear shooting board can
be used as well.
Also, contractor type table saws usually heel
when tilted due to the weight of the motor
pulling unevenly on the trunnions.
Lazyman
#11 posted 11-06-2017 06:44 PM
If you cannot tune up the saw to fix this, you may be able to fix the boards after cutting using a miter shooting board. Cut them a smidge long and trim to final length with a hand plane and shooting board.
Kelly
#12 posted 11-06-2017 09:15 PM
Thanks for your input! You have given me several options to consider as I narrow down how best to address this problem. One thing I didn’t make clear is that the mitered edge on this project was 16” long, I realized that in my drawing it doesn’t look that long. So cutting from a sled would probably be more difficult than just running the wood along the fence. Also, the wood is very soft (pine) and 1/2” in thickness. But, that being said I’ll start with making sure the ZCI is dead flat and through your suggestions.
Any other ideas/input is welcome!
Thanks again!
View poospleasures's profile
poospleasures
734 posts in 2483 days
#13 posted 11-07-2017 12:15 AM
I very seldom tilt the table saw blade. I made a 45 degree (adjustable ) about 10 or so years ago and tinkered with it until perfect and have made hundreds of boxes with it and every miter joint is exact. I don,t have a picture of this jig, but if you want to PM me I will make one and send it.
-- I,ve had amnesia for as long as I can remember. Vernon
View sawdustdad's profile
sawdustdad
354 posts in 884 days
#14 posted 11-07-2017 01:20 AM
Not mentioned, but equally important as the angle is consistent lengths—be sure each side of the box is the exact same length. I use stop blocks on the sled to be sure exact lengths.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
