Will this mortise hold?
« back to Joinery forum
Forum topic by Mcpowell posted 11-05-2017 07:50 PM 1357 views 0 times favorited 16 replies Add to Favorites Watch
View Mcpowell's profile
Mcpowell
49 posts in 1124 days
11-05-2017 07:50 PM
Topic tags/keywords: walnut mortise knot epoxy
I wanted to use this piece of walnut as the knots give this chair leg a lot of character. Unfortunately, after I was a good way into the project, I noticed this knot was going to line up with my mortise. I do have a spare leg I can fall back on, as I made an extra blank, but that will take several hours to complete. After figuring out how this was all going to line up, I decided to push onward, make the mortise and see how solid the area felt. Well, it’s not very solid. I can move the .400” thick area with my fingers. It’s not brittle, but there really isn’t much strength in the area between the mortise and the edge of the chair. I have plenty of epoxy resin. To give you some size reference, the mortise is 2” long and .5” wide.
1) Do you think this will have enough strength to hold if I fill the void/knot with epoxy?
2) If you think the epoxy will hold, should I epoxy first, or glue the joint with titebond and then fill in the knot with epoxy after the glue has set?
Any suggestions?
-- I want to be good
16 replies so far
View jmos's profile
jmos
905 posts in 2603 days
#1 posted 11-05-2017 07:56 PM
Personally, I would not trust it, especially not in a chair. Just think how much lost time if you push on and it fails in use. I’d be safe and make a new leg.
If you do decide to epoxy, I’d think you would be best off using the epoxy to assemble the joint and fill the knot at the same time.
-- John
View Loren's profile
10477 posts in 3882 days
#2 posted 11-05-2017 08:00 PM
Even if the knot doesn’t pop out the distorted
tissue will move strangely and the joint will
probably loosen as a result.
View Jess Littlefield's profile
Jess Littlefield
166 posts in 2843 days
#3 posted 11-05-2017 08:28 PM
Is this one of the rockers? If so I would not use it. What happens if you could make the mortise and tenon two or three times deeper which would probably help. And instead of using glue I would use 2 part epoxy and using air pressure after you apply the epoxy let the air pressure force the epoxy as deep as you can get it. I use a rubber tip blo gun for that purpose. Also as the air flows cover the area with a rag or else some will escape and cover the walls.
Halfacre, Jess
-- Jess Littlefield
Mcpowell
#4 posted 11-05-2017 09:05 PM
Personally, I would not trust it, especially not in a chair. Just think how much lost time if you push on and it fails in use. I d be safe and make a new leg.
If you do decide to epoxy, I d think you would be best off using the epoxy to assemble the joint and fill the knot at the same time.
- jmos
John,
This is exactly what my son and I discussed at lunch. Work 3-5 hours and make a new leg, or end up throwing away the whole chair when it breaks in a few years. Ugh…can you hear my whining across the internet?
Mcpowell
#5 posted 11-05-2017 09:11 PM
Even if the knot doesn t pop out the distorted
- Loren
I know you are right, but I wish your answer was different. ;-)
Mcpowell
#6 posted 11-05-2017 09:15 PM
Halfacre, Jess
- halfacre
Jess,
It’s not a rocker, it is one of the chair backs. The pictured mortise faces forward. Hopefully the drawing will illustrate.
View Aj2's profile
Aj2
1941 posts in 2032 days
#7 posted 11-06-2017 01:27 AM
If you don’t use that piece it would make a good test piece. I would fit a scrap tenon in there epoxy it all together let it cure. Then see how much it takes to break the joint.
I’d be interested to see if it’s strong.
Let the record show I think it will be good if you use epoxy.
-- Aj
Mcpowell
#8 posted 11-06-2017 02:16 AM
If you don t use that piece it would make a good test piece. I would fit a scrap tenon in there epoxy it all together let it cure. Then see how much it takes to break the joint.
I d be interested to see if it s strong.
- Aj2
AJ,
That is a good idea. I have at least one extra piece of each component. I figured I would screw something up somewhere along the line while trying to build 8 chairs. It might be a month or so before I have a leftover or scrap horizontal pieces, but I’ll definitely test it.
Any suggestions as to how to measure the results? I’m unwilling to waist a good leg, but I guess I could make another mortise from just a block of good wood.
Mark
View Gilley23's profile
Gilley23
489 posts in 616 days
#9 posted 11-06-2017 02:56 AM
Any suggestions as to how to measure the results? I m unwilling to waist a good leg, but I guess I could make another mortise from just a block of good wood.
Mark
- Mcpowell
Mark, check this out: https://youtu.be/apsH8eBfjVA
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#10 posted 11-06-2017 03:49 AM
As long as the knot is epoxied in well I don’t see it being that big of a deal.
View Andre's profile
Andre
2346 posts in 2040 days
#11 posted 11-06-2017 06:57 AM
Back side and both ends solid so with a tight fit no problem!
Mcpowell
#12 posted 11-07-2017 06:41 PM
So a friend and I were chatting about this and he suggested I build 9 chairs instead of 8. So I think I’m going to give that a try. It just keeps me from having spare parts in the event I really screw something up along the way. So I think I’ll use this leg on my 9th chair.
For this leg with the inconvenient knot….would it be helpful to the strength of the mortise and tenon if I drilled a few holes through the knot, into the tenon, and then screwed them together. This seems like it would provide a bit more horizontal strength to the joint and I could fill the drilled holes with black epoxy (which should match the knot fairly well). I’ll use epoxy as the glue on this one through and through regardless.
View pontic's profile
pontic
663 posts in 842 days
#13 posted 11-07-2017 10:02 PM
You could rout or chisel out more of the knot area and about a3/8” above and below it and place it a walnut plate that has smooth strong straight grain. Make the plate about 1/4 ” thick and bed it in there with epoxy. then seat your tenon with epoxy. You know that you have more splits running with the grain to worry about than just that knot.
-- Illigitimii non carburundum sum
View rwe2156's profile
rwe2156
3225 posts in 1714 days
#14 posted 11-08-2017 01:51 PM
- Mcpowell
I think this would weaken it even more and probably cause the knot to fail.
I would route the whole thing out flush to mortise wall and 1” past the ends & glue in a patch.
runswithscissors
2916 posts in 2259 days
#15 posted 11-11-2017 12:40 AM
Pontic’s suggestion sounds best to me.
