fasten a 4x4 to pavement
Forum topic by GR8HUNTER posted 11-05-2017 07:09 PM 802 views 0 times favorited 8 replies Add to Favorites Watch
View GR8HUNTER's profile
GR8HUNTER
4928 posts in 888 days
11-05-2017 07:09 PM
Topic tags/keywords: question 4x4 pavement
hello all ,,,I need to fasten a 4×4 PT 3 foot high to pavement this project is for a trash can enclosure to be built of the back of a shed 3 feet of shed around 6 feet wide with a gate on front looking for ideas how to fasten corner post 4×4 3 foot high PT to pavement THANKS FOR ALL REPLYS :<))
8 replies so far
View lew's profile
lew
12382 posts in 3931 days
#1 posted 11-05-2017 07:16 PM
View JoeinGa's profile
JoeinGa
7739 posts in 2183 days
#2 posted 11-05-2017 07:24 PM
I dont think the bracket Lew shows would work on pavement. ( You DO mean “TAR” or “Blacktop” dont you? )
I think I’d find a way to make a hole in the pavement (even if it means using a long drill bit to drill around the edge) and then digging out the plug. The use a two-handled post hole digger to dig it the rest of the way. Sink the 4X4 and patch around it.
GR8HUNTER
#3 posted 11-05-2017 07:35 PM
yes Joe Blacktop ,asphalt ,pavement didn’t really think I needed to sink the 4×4 since it is only for light fencing or don’t feel like that much work LMAO :<)) Maybe that thing lew posted would work if they have them for 4×4 and fasteners for blacktop ?
View MrRon's profile
MrRon
5141 posts in 3419 days
#4 posted 11-05-2017 07:43 PM
Any base similar to the one recommended by Lew is not recommended when the top of the post is not supported as in fence post. If the pavement is asphalt or other “soft”material, you can get a steel post that has a spike on the end and attaches to the bottom of your 4×4. The post is then driven into the ground. These are used for attaching mailboxes to posts. https://www.lowes.com/pd/USP-Steel-Painted-Post-Base-Common-4-in-Actual-4-in/3365692
View jerryminer's profile
jerryminer
944 posts in 1617 days
#5 posted 11-05-2017 08:30 PM
The bracket in the link posted by lew above will keep the bottom of the post in place, but will not keep the post plumb (upright). If you hang a gate on the post, the gate will sag, guaranteed.
Better option, IMHO is one like this: Post Base
GR8HUNTER
#6 posted 11-05-2017 08:34 PM
that looks more like what I was thinking of Jerry now is there a fastener for blacktop , pavement ?
jerryminer
#7 posted 11-05-2017 08:46 PM
I like wedge anchors, like these
View WhyMe's profile
WhyMe
1061 posts in 1737 days
#8 posted 11-05-2017 10:22 PM
Wedge anchors will not work in asphalt. The only thing that will come close to holding up a post on asphalt is what MrRon linked. Asphalt has no holding strength if using mechanical fasteners to prevent top lateral movement.
