RAS's and SCMS's
Forum topic by MrRon posted 11-05-2017 07:08 PM 823 views 0 times favorited 14 replies Add to Favorites Watch
View MrRon's profile
MrRon
4988 posts in 3361 days
11-05-2017 07:08 PM
Topic tags/keywords: miter saw radial arm saw
Before sliding compound miter saws(SCMS), there were radial arm saws(RAS). Miter saws then added rails so the head could slide rather than to just cut on the “chop” stroke. It now resembles the RAS, except for the “chop” feature. Why is it said to pull the head forward, then put in the chop position and then push the blade away from you. This doesn’t make sense to me. Pushing the blade away from you with the teeth cutting on the up stroke would, I observe, tend to lift the wood up away from the table as shown in the top sketch. In the bottom sketch, the cutting action tends to press the wood down against the table. The Ras also tends to self feed, but that is minimized by using a blade with positive rake.
14 replies so far
View Carloz's profile
Carloz
1147 posts in 709 days
#1 posted 11-05-2017 08:13 PM
Cutting tools like saws and routers behave very unpredictably when cutting along the blade rotation.
View MrUnix's profile
MrUnix
6887 posts in 2316 days
#2 posted 11-05-2017 09:28 PM
RAS has a fixed arm that won’t allow the motor/blade to kick up… SCMS will. If you have ever pulled back on a SCMS and had it hit the wood, you will know why. Cutting from front to back (SCSM) causes the direction of cut to push the blade down towards the table. There is nothing unpredictable about it, just physics.
View timmib's profile
timmib
10 posts in 882 days
#3 posted 11-05-2017 09:46 PM
I’m not sure what your question is. The design of a RAS is such that if you are ripping the cutting head will/can race towards the operator.
-- Kim, Chillicothe, MO
View jbay's profile (online now)
jbay
2588 posts in 1017 days
#4 posted 11-05-2017 11:59 PM
”Why is it said to pull the head forward, then put in the chop position and then push the blade away from you. This doesn’t make sense to me.”
I’ve never heard that that is what is said. Personal preference as far as I know. (which may not be much)
I don’t like chopping into the wood and pulling because of the stress it puts on the saw with so many teeth cutting into the board at one time. (see below)
I’ve never experienced the wood lifting from the table so in my experience that’s a non factor for me.
Chopping into the wood compared to pushing into the wood:
View Woodknack's profile
Woodknack
12331 posts in 2497 days
#5 posted 11-06-2017 02:54 AM
- MrRon
I think you meant to type, negative rake.
The answer to your question is to avoid climb cutting. Same reason you feed against the rotation of a router bit.
5069 posts in 2611 days
#6 posted 11-06-2017 11:40 AM
I m not sure what your question is. The design of a RAS is such that if you are ripping the cutting head will/can race towards the operator.
- timmib
Actually if you are ripping (something I don’t do on mine) the cutting head should be locked and turned 90°, there’s no way it can “race” at you. But the work piece can sure come flying out…among other undesirable happenings. But even on a cross cut, the head can’t “run at you”. Because it’s held firmly by the arm, what happens if the self feed is bad enough is the blade gets jammed and stalls the motor.
View jonah's profile
jonah
1837 posts in 3416 days
#7 posted 11-06-2017 03:10 PM
The rotation of the blade when you’re pushing towards the fence wants to fling the work piece forward away from the blade and down away from the blade. In both directions there’s a metal table preventing that from happening.
It’s the same with a table saw, just on the other side of the blade. The blade wants to fling the piece towards you and up.
Carloz
#8 posted 11-06-2017 03:54 PM
MrRon
#9 posted 11-06-2017 05:41 PM
- MrRon
- Rick_M
Yes! I did mean negative rake; thank you for the correction.
View Srini's profile
Srini
29 posts in 897 days
#10 posted 11-06-2017 09:53 PM
RAS has a fixed arm that won t allow the motor/blade to kick up… SCMS will. If you have ever pulled back on a SCMS and had it hit the wood, you will know why. Cutting from front to back (SCSM) causes the direction of cut to push the blade down towards the table. There is nothing unpredictable about it, just physics.
- MrUnix
How does Cutting from front to back (SCSM) causes the direction of cut to push the blade down towards the table? As Mr.Ron shown in the diagram, when you cut from front to back (away from operator), the blade cuts fresh stock in its upwards direction (that is what the leading edge of the blade in that direction).
I think Ron’s question is not answered.
MrUnix
#11 posted 11-06-2017 10:24 PM
- Srini
The resistive force applied to a cutting edge is opposite its direction of travel. If the blade is cutting from the top, it wants to push the blade upwards. If the blade is cutting from the bottom, it wants to push the blade downwards. Same deal with a router, which many people are more familiar with (but left/right instead of top/bottom).
Woodknack
#12 posted 11-06-2017 11:12 PM
I think Ron s question is not answered.
- Srini
I answered it.
View sawdustdad's profile
sawdustdad
364 posts in 1002 days
#13 posted 11-07-2017 01:59 AM
Funny. I just took my 35 year old Craftsman RAS to the dump last week. Haven’t used it in at least 15 years. Set it down in the “free stuff” pile at the county’s waste transfer station. Been using a SCMS for all cross cutting.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
MrUnix
#14 posted 11-07-2017 02:03 AM
Funny. I just took my 35 year old Craftsman RAS to the dump last week. Haven t used it in at least 15 years. Set it down in the “free stuff” pile at the county s waste transfer station. Been using a SCMS for all cross cutting.
- sawdustdad
Depending on which model you had, you might of got $100 for it through the recall. I picked up one for $65, sent in the motor for $100, and am turning the frame into an overarm router table :)
