Best Finish for Ipe Deck
Forum topic by Lazyman posted 11-05-2017 04:33 PM 734 views 0 times favorited 12 replies Add to Favorites Watch
View Lazyman's profile (online now)
Lazyman
2271 posts in 1468 days
11-05-2017 04:33 PM
Topic tags/keywords: truck bed ipe oil deck finishing
..Well it is actually for a pickup truck bed replacement. A friend of mine is restoring or rather rebuilding from the ground up an old pickup truck with a wood bed and decided to use ipe instead of the standard oak boards it originally had. He is thinking about using Deckwise Ipe Oil to finish it, instead of leaving it natural. I know that on exposed decks, you have to reapply the oil every few years but his truck will likely be garaged when not in use so will see minimal UV and weather compared to a deck so should last a few years longer between new applications. With as much time as he spending to rebuild it I doubt that he will haul anything for a while that would scratch the paint much less the bed decking so wear is probably not much of an issue.
So my question is first what do you think of Deckwise Ipe Oil and second do you have any better choices and why? I appreciate any experiences or watchouts you may have, especially for this application.
Here’s a picture of the bed after mounting the ipe.
12 replies so far
View Aj2's profile
Aj2
1580 posts in 1879 days
#1 posted 11-05-2017 05:07 PM
Wow that looks great. If it were mine to show off I’d just build up some shellac. Shellac is more durable then most know especially button lac that still has its wax.
Plus I have lots to use.:)
-- Aj
117165 posts in 3658 days
#2 posted 11-05-2017 05:55 PM
Shellac is not very water resistant
Most outdoor finishes break down in sunlight, I would use teak or walnut oil and renew it every few months ,going this route means there’s not any build up and no removal of old buildup old finishes like you would have to do with a poly or marine varnish.
Edit
after rereading your post sounds like that’s close to what you had in mind, of course, Ipe will hold up very well without a finish.
View tyvekboy's profile
tyvekboy
1783 posts in 3094 days
#3 posted 11-05-2017 06:50 PM
Beautiful truck bed. I second teak or walnut oil.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View AandCstyle's profile
AandCstyle
3132 posts in 2338 days
#4 posted 11-05-2017 11:10 PM
Nathan, you might consider clear paint. FWIW
-- Art
Lazyman
#5 posted 11-07-2017 03:14 AM
Thanks for the input.
View Dark_Lightning's profile
Dark_Lightning
3187 posts in 3190 days
#6 posted 11-08-2017 02:35 PM
Long bed stepside, very nice! That ipe will last forever, even without a finish.
-- Random Orbital Nailer
Dark_Lightning
#7 posted 11-08-2017 02:37 PM
- AandCstyle
That, and some of the newer automotive clears are tough as nails.
View splintergroup's profile (online now)
splintergroup
2203 posts in 1303 days
#8 posted 11-08-2017 03:00 PM
If he decides on a film type finish, the clear (automotive) paint idea seems best to me as well. Any other film finish will need to be sanded/removed when re-applying.
If automotive paint is used, a flex additive should be used (like what is added for those plastic bumper covers). The wood will move some and the paint needs to follow suit.
Ipe is great outdoors without any finish, but it will turn grey.
Lazyman
#9 posted 11-08-2017 03:45 PM
- splintergroup
Thanks, I’ll pass that along to my friend. I doubt that he will want to go that route because of the trouble it’ll take to strip to refinish it down the road. I am also concerned that a film finish will trap moisture inside at some point because cracks or scratches in the finish are inevitable which will eventually lead to mildew. With the oil based finish, if and when he decides refinishing is too much trouble, he can must let it go grey, which may actually go very nicely with the blue color. He painted the truck to match its original color by the way.
Dark_Lightning
#10 posted 11-09-2017 03:57 AM
The bed of my truck was painted with the same lacquer that the rest of the truck was painted with. It holds up better than you might think.
splintergroup
#11 posted 11-09-2017 01:57 PM
- Dark_Lightning
I loved auto lacquer.
It’s a lot softer then the activated paints, but it doesn’t “tear” like they do, instead it scratches, but is incredibly easy to blend and repair.
Lazyman
#12 posted 11-15-2017 02:58 PM
Thanks again for all the input. He went with Deckwise Ipe Oil and it looks great. He sent off for a free sample expecting to get a ketchup pouch size sample to try on some scraps but they actually sent him enough to finish the entire bed…so he did
