How do I remove wood from this area?
« back to Hand Tools forum
Forum topic by rolandstronghammer posted 11-05-2017 04:20 PM 480 views 0 times favorited 5 replies Add to Favorites Watch
View rolandstronghammer's profile
49 posts in 798 days
11-05-2017 04:20 PM
I’m making a coffee table out of this peice of maple I cut a couple years back. Not sure how to remove the bark from this spot. I used a belt sander on the rest of it but can’t get it into this area. Any suggestions?
I was thinking of getting a set of rasps. I tried a flap disc in an angle grinder but it spins to fast and burns the wood.
Thanks for your suggestions
5 replies so far
Rick Dennington
5746 posts in 3130 days
#1 posted 11-05-2017 05:18 PM
I would use a chisel and also a rasp and make real light passes till all the bark is removed the way you want it….Use different size chisels to get into the tight spots, then use a small block and sandpaper to get to the areas you can with it, then fold the sandpaper to get into the tight spots….
View bandit571's profile
19528 posts in 2619 days
#2 posted 11-05-2017 05:31 PM
Sabre saw with a long blade. Then the rasps.
117032 posts in 3513 days
#3 posted 11-05-2017 05:48 PM
If you’re careful a multi-tool might do the job.
-- wood crafting & classes
View Ripper70's profile
903 posts in 844 days
#4 posted 11-05-2017 06:08 PM
Coping saw.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View timmib's profile
10 posts in 701 days
#5 posted 11-05-2017 06:16 PM
I’d be inclined to explore useing a portable drill press with varying small rasp bits, or better yet cut long thin strips of sand paper (perhaps old pieces of belt sander material) to pull back and forth through the area.
-- Kim, Chillicothe, MO
