My First Snowman - Man, I Hate Spindle Turning!
« back to Woodturning forum
Forum topic by Madrona posted 11-02-2017 12:36 AM 1933 views 0 times favorited 14 replies Add to Favorites Watch
View Madrona's profile
Madrona
113 posts in 1014 days
11-02-2017 12:36 AM
Thought I would try turning a snowman, even though I suck at spindle turning. Turned out OK but I’m not sure I want to make another… But I did make a video:
https://www.youtube.com/watch?v=OgvwJ_cVLFM
-- Living In The Woods Of Beautiful Bonney Lake, Washington
14 replies so far
View Wildwood's profile
Wildwood
2407 posts in 2253 days
#1 posted 11-02-2017 12:12 PM
Think your snowman looks outstanding, and enjoyed the video. Not the first woodturner heard to say or know doesn’t like spindle turning but that okay. Kind of shows in your video again that is okay finish project turned out very well.
Thanks for sharing!
-- Bill
View Carloz's profile
Carloz
1147 posts in 710 days
#2 posted 11-02-2017 01:12 PM
What about taking care of the cutter ring marks before finishing?
Madrona
#3 posted 11-02-2017 07:00 PM
Thanks for sharing!
- Wildwood
Thanks, Wildwood! The spindle turning thing is kind of a problem and I know it limits what I do on the lathe. I guess I’ll just have to force myself to do more of them to get more comfortable. “Learn one thing each day.” :)
Madrona
#4 posted 11-02-2017 07:07 PM
- Carloz
Cutter ring marks? Not sure what that is, Carloz. Do you mean tool marks? Do you see any in the finished product? I looked it over real well after I read you comment and I just don’t see any. You may be seeing the reflection of light which casts a bit of a shadow from the head to the body. I agree, tool marks will just destroy a piece, when present. Thanks for your comment!
Wildwood
#5 posted 11-03-2017 10:23 AM
Only know Reed Gray from the message boards & his videos, been turning as long or than I have and doesn’t care much for spindle turning. Know several other turners that only turn bowls or hollow forms and don’t own any spindle turning tools much less how to use them. Also so know many turners that started with spindle turning but switch to nothing but bowls.
https://www.robohippy.net/gallery/
If there is any rule in woodturning guess it would be don’t be afraid to try something new. Don’t worry about failures just show us your sucesses!
I like love all aspects of bowl & spindle turning and just getting started in hollow forms. Defitinely not going to show where went thru sides of a hollow form using not using my homemade laser set up.
-- Bill
View BlasterStumps's profile
BlasterStumps
861 posts in 558 days
#6 posted 11-03-2017 12:23 PM
Madrona, you did a nice job aligning the snowman features with the growth rings. Turned out really well.
Mike
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
Madrona
#7 posted 11-04-2017 01:21 AM
Mike
- BlasterStumps
Thanks so much, Mike, I appreciate that!
Madrona
#8 posted 11-04-2017 01:24 AM
- Wildwood
Thanks for the encouragement, Bill. Knowing others are similarly inflicted helps! I am definitely going to make more snowmen and have done other, small, spindle turnings like whistles and cup and ball toys. Just gotta practice more, like you say, to get more comfortable. I don’t like feeling limited.
View Kelly's profile
Kelly
2073 posts in 3063 days
#9 posted 11-04-2017 02:14 AM
Interesting. I love spindle turning because there are so many things I can do with it. That can be the simple, like this, to more complicated turnings that require precision mortises and tenons.
I belong to a turning club and some of the guys there are nationally known [and deserving of it]. I love their bowls, vases, cowboy hats and so on. However, I prefer pursuing functional or artful from another direction. For example, cutting the ends off a wine bottle, then turning pieces of wood that fit into it and of the same outer dimension, then placing lights in the end product.
PS Carlos was, probably, seeing the line just under the chin and one about where the mouth would be. Things I fight all the time. Slowing the lath down during sanding helps, as does going to a skew (maybe). I’ve also found using a wood stick designed to hold the sand paper against the wood “sometimes” helps. In the end, they may not be important in most jobs and it, certainly, did not detract from this one.
In the end, thanks for sharing and the reminder to not ignore the fun stuff.
Madrona
#10 posted 11-04-2017 06:12 AM
PS Carlos was, probably, seeing the line just under the chin and one about where the mouth would be. Things I fight all the time. Slowing the lath down during sanding helps, as does going to a skew (maybe). I ve also found using a wood stick designed to hold the sand paper against the wood “sometimes” helps. In the end, they may not be important in most jobs and it, certainly, did not detract from this one.
- Kelly
Oh, I get it now! I forgot I even posted a picture and that’s what you and Carlos are referring to. I thought the tool marks were from the video. That’s why I asked if it was seen in the finished product. I just went and looked again. Shadows. What can I say, I don’t have a good lighting set up for photographs. I assure you, there are no tool marks on this snowman. I have, however, finished pieces and then noticed and had to remount, return, re-sand to take care of the issue. They just drive me nuts, too!
Thank you Kelly for your well thought out reply and reminder. I really need to stop in at our local turning club and see what’s up. I know clubs like that can be a valuable resource.
Your wine bottle project sounds like an ideal project for the wife and I. I could do the turning, she could do the decorating. I’ll run your idea past her, thanks!
View Hockey's profile
Hockey
138 posts in 531 days
#11 posted 11-04-2017 02:50 PM
For those of us with midi/mini lathes, spindle turning gives an additional type of project to make other than just small bowls. In addition to small bowls, I like to turn boxes, goblets and ornametal birdhouses. If I had a full size lathe, I probably would still like to do as much spindle turning.
By the way, very nice snowman.
View richardchaos's profile
richardchaos
583 posts in 498 days
#12 posted 11-04-2017 02:53 PM
How did you keep it from melting?
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View Jackryan's profile
Jackryan
7 posts in 1994 days
#13 posted 11-04-2017 03:36 PM
Would it be smaller if you used a friction finish?
-- Dave, Wi.
Madrona
#14 posted 11-05-2017 05:52 AM
- richardchaos
- Jackryan
You guys crack me up! LOL
