Veneer suppliers and equipment
Forum topic by natenaaron posted 11-01-2017 06:10 PM 692 views 1 time favorited 11 replies Add to Favorites Watch
View natenaaron's profile
natenaaron
442 posts in 1998 days
11-01-2017 06:10 PM
I want to play with veneer. There is no one near me who sells it so I will have to order. Ths means I need a reputable supplier. So, I am approaching the community to find an upstanding veneer supplier.
I don’t have the money for a vac bag system. I like the idea of the clothes iron method of attaching but is it too easy to be effective?
11 replies so far
5176 posts in 2694 days
#1 posted 11-01-2017 06:13 PM
Check out Veneer Supplies (sometimes called Joe Woodworker). Everything you need, including stuff to build your own press, and great CS. I built mine using one of Joe’s rebuilt Thomas pumps (7-8 years ago) and it has worked great.
View Loren's profile
10477 posts in 3848 days
#2 posted 11-01-2017 06:18 PM
As long as your panels are of modest size
and flat you can press veneers with a lot
of regular clamps. You’ll be limited by
the throat depths of your clamps.
I’ve never ironed it on by heating dried PVA
glue. It seems to me like a method better
suited to making repairs than new work.
The traditional way to do it with hot hide glue
works very well. I’ve been too intimidated to
try it myself but I suspect it’s easier than it
looks.
View DS's profile
DS
3033 posts in 2621 days
#3 posted 11-01-2017 08:59 PM
Some good suggestions here;
http://lumberjocks.com/topics/236457
View jmos's profile
jmos
902 posts in 2570 days
#4 posted 11-01-2017 11:54 PM
I’ve had good luck with Joe Woodworker also.
My work has been limited to smaller panels. I bought two 1/4 sheets of melamine coated chip board from the big box store and use pieces of them as a press (nice because the glue doesn’t stick.) With some boards as cauls and my regular F-style clamps I’ve had pretty good luck with clamping them up.
The trick I found was not to use too much glue; my first attempts were too wet and the panels had terrible ripples. I’ve never tried ironing it, nor hot hide glue.
-- John
View jmartel's profile
jmartel
8231 posts in 2350 days
#5 posted 11-02-2017 12:35 AM
Best place to get veneer is www.certainlywood.com
You don’t need a vacuum bag at all. If you are just doing smaller flat panels, pick up some titebond cold press glue and use that. Once you start using veneer more, switch over to hide glue. Definitely the best option as it’s reversible and fixable if you mess up. A veneer hammer, hide glue, and something to keep the glue hot is all you need.
View AlaskaGuy's profile
AlaskaGuy
4786 posts in 2510 days
#6 posted 11-02-2017 01:04 AM
Joe woodworker has a ton of information on that site if you dig around a bit. I think it’s a great place for a newbie.
View DS's profile
DS
#7 posted 11-02-2017 06:34 PM
Most local hardwood suppliers will offer veneer sheets.
#8 posted 11-02-2017 08:11 PM
You can buy paper back veneer. It’s real
easy to work with but the figure is generally
bland.
View rustynails's profile
rustynails
802 posts in 2729 days
#9 posted 11-02-2017 11:13 PM
B&B Rare Woods <veneers> great prices. Talk to Dave.
natenaaron
#10 posted 12-02-2017 10:36 PM
I stopped off at Woodworker’s Supply in Phoenix, since I was down there anyway, and holy cow, their veneer is expensive.
Gonna order it.
rustynails
#11 posted 12-03-2017 12:01 AM
I stopped off at Woodworker s Supply in Phoenix, since I was down there anyway, and holy cow, their veneer is expensive.
Gonna order it.
- natenaaron
